NOISE IN FRONT END!!
Old Mar 30, 2007 | 06:16 PM
Mosie84's Avatar
Default NOISE IN FRONT END!!
Recently got stuck on a curb in a bad snow storm. Since then have noticed a rubbing or grinding noise coming from the front end of my car. Does it if I am going straight or turning, but only occurs when I am between 20 - 50 mph... over and under no noise? Any suggestions of what it is??
Old Mar 30, 2007 | 06:18 PM
Mosie84's Avatar
Default RE: NOISE IN FRONT END!!
1999 A4 18.T Quattro
x1rider's Avatar
If there is snow stuck in your rim, it can cause an imbalance in the wheel causing vibrations/noise (it happened to me a few years ago).
Old Mar 30, 2007 | 06:20 PM
zrwhat's Avatar
ORIGINAL: x1rider
ugh, i been there before too, lol
SacTown_Vlad's Avatar
turn your wheels all the way to the side and get under there…. it’s probably one of the plastic dirt guar, see if it’s uptight anywhere…
Old Mar 30, 2007 | 06:21 PM
new2me's Avatar
Could of knocked off the weights also.
Check the tie rods
Old Mar 30, 2007 | 06:36 PM
Mosie84's Avatar
Rims are fairly clean now... most of the snow is gone...
Old Mar 30, 2007 | 06:42 PM
new2me's Avatar
Did you check to see if you lost some wheel weights?
I hit a pot hole and lost mine off my front tire which is causing a vib. at 40 mph.
Old Mar 30, 2007 | 07:06 PM
Mosie84's Avatar
I don't think it has something to do with wheel balance, because there is no vibration, just a rubbing to grinding noise
Old Mar 30, 2007 | 07:41 PM
new2me's Avatar
Maybe a bit more detail with the situation that caused this problem. Did you smack a curb with a tire during this also? What tire was hit or stuck? Maybe you have torn a cv boot.
