noise from rear wheel
driving down the road, the drivers side rear wheel makes a loud buzzing noise... it is speed sensitive, and stops when i make a right turn (at speed) does anyone have any ideas on this?
thanks, chris |
RE: noise from rear wheel
Wheel bearing??
is this a normal thing to go wrong? this thing is LOUD, but only stops when i go around a right hand bend... wouldnt a wheel bearing stop going both ways? ill look in the bentley book
it's your wheel bearing...ecstuning sells a new kit for about 60 bucks, you can do it yourself or you can pay a mechanic usually about 100 bucks to do it for you
thank you, simple enough, if i can rebuild the motor, im sure i can handle a wheel bearing... but you are sure thats what it is?
99% sure had same problem with a 91 200tq and wheel bearings fixed it
if it turns out to be something else, i'll pay for your bearing kit ;)
if your doing it your self just be careful with the ABS speed sensor its easily damaged when removing and refitting parts
yea it's prolly the wheel bearing, alot of ppl have a similar prob. i've got it on the left rear. i'm gonna change it in a bit.
if the bearing goes it will out take the ABS sensor with it so change it ASAP
