AudiForums.com
-   Audi A4 (https://www.audiforums.com/forum/audi-a4-8/)
-   -   noise from rear wheel (https://www.audiforums.com/forum/audi-a4-8/noise-rear-wheel-28321/)
DVA 03-28-2006 07:31 PM
RE: noise from rear wheel
ORIGINAL: xx18quattroxx
thank you, simple enough, if i can rebuild the motor, im sure i can handle a wheel bearing... but you are sure thats what it is?
well I`m sure it isn`t :) I have the same problem it`s only when up to 50 mph and louder when I turn left a little... but it stops to low speed and when I turn right also.. I tough there is something wrong with the braking pads and rotors but it isn`t. don`t know what to say..
oh btw the noise it`s coming from the front driver side wheel..
BFlan2001 03-28-2006 07:34 PM
ORIGINAL: DVA
i do...it's the wheel bearing.
BadLuckAudi 03-28-2006 07:54 PM
LOL how many times do we need to say wheel bearing before they figure it out lol
fastmayte 03-28-2006 08:26 PM
Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing[:'(][:@][8D][X(][&o][:-][>:]:)[&:]:D
