Noob question--RIMS
Old Jun 18, 2007 | 01:45 PM
ballswell's Avatar
Default Noob question--RIMS
2003 A4 1.8T.. Looking at buying HP EVO Hyper Silver Dark, and need specs for my model. (I don't have a manual for my model)
18" x 9" 38mm offset and 5x112 bolt pattern <==Would this fit my model front and back? would it hurt to do 18x9 in back and 18x8 in front?
Thanks,
Old Jun 18, 2007 | 01:48 PM
1996audiA4's Avatar
Default RE: Noob question--RIMS
Do you have Quattro? If you have quattro you have to use the same size rims, or you're supposed to at least. It is bad for an AWD car to use different size rims.
Old Jun 18, 2007 | 01:50 PM
ballswell's Avatar
Yes, quattro, sorry. Will 18x9's fit a B6 front and back? I found a good deal on them, that's why I'm so specific to the 18x9. Thanks..
Old Jun 18, 2007 | 04:34 PM
headshok2002's Avatar
Yeesh, don't know if you can fit a 9" up front with a 38mm offset... maybe... but yeah, tough call.
I run 8.5" fronts on a B5 with a perfect 32mm offset... B6's have more room, though. Are you lowered?
Old Jun 18, 2007 | 05:12 PM
ballswell's Avatar
No, stock. Sport.
Old Jun 18, 2007 | 05:26 PM
Yeah, tough call... My dad has CH's on stock sport, which are 8.5... but 32mm offset on them, too. I've never jacked it up to see what kind of clearance he has on the inside. It'll be the inside where you may rub, with 9" tires and 38mm offset.
Yeah, tough call... My dad has CH's on stock sport, which are 8.5... but 32mm offset on them, too. I've never jacked it up to see what kind of clearance he has on the inside. It'll be the inside where you may rub, with 9" wheels and 38mm offset.
Old Jun 18, 2007 | 05:31 PM
1996audiA4's Avatar
8.5 with a 35mm offset is very common, but 9" is gonna be a squeeze. I would call tire rack or some company that sells rims. They should be able to tell you if they'll fit or not.[sm=icon_cheers.gif]
A4audiB5
Mar 10, 2013 08:46 AM
The_Almighty_DEBBS
Nov 3, 2012 05:29 PM
ryoungblood0
Jun 21, 2011 09:19 PM
TSHARK
Apr 27, 2007 01:23 PM
Airmen
Mar 31, 2007 07:25 PM
