nooby help again
Old Oct 26, 2006 | 09:02 PM
keko2004's Avatar
Default nooby help again
i included a pic of what the part is called. what i circled i htink is a bushing. on my car it looks destroyed. can i fix this, if so whats the name of the part to get so i can fix it.
also, i jacked up my car to check for bad tie rods. i wiggled the wheel from left to right and found about 1inch max of play. time for new tie rods?
Old Oct 26, 2006 | 09:45 PM
Jeff's Avatar
Zombie Defense Force
Default RE: nooby help again
ya thats a lot of play. shouldnt have that much.
Old Oct 26, 2006 | 10:12 PM
keko2004's Avatar
sooo. i know thats a lot, do i need tie rods. should i take it to a mechanice to check out?
Old Oct 26, 2006 | 10:21 PM
david9999's Avatar
There should be NO play. The circled part is tie rod end.
It is a DIY if you can get the bolts off. Many times these are rusted tight.
I'd have your friendly mechanic fix it. Get the upgraded heavy duty tie rod end on the net.
Old Oct 27, 2006 | 02:45 PM
acetrebo's Avatar
ORIGINAL: keko2004
Dude, I already told you in your other post, replace the tie-rod ends.
That is the part you have circled. Sounds like you should have a shop do this for you.
There is a DIY article here:
http://www.audiworld.com/tech/wheel.html
automotivesuppliers
Feb 11, 2010 12:07 PM
Tirrany2000
Aug 5, 2008 08:48 PM
jmac2876
Aug 6, 2006 06:10 AM
onepoint8tee
May 9, 2006 07:42 PM
