not a big deal but confused
Old May 25, 2005 | 01:16 AM
toastbiscuit's Avatar
Default not a big deal but confused
yeah so lately whenever i take my car ('01 1.8tq) on even a short drive, the second little coilpack from the engine pops up about an inch. I haven't noticed a miss or any codes so it's hard for me to tell how long it's been doing this. I also tried tightening the spark plug just a touch to see if mabey there was some compression coming through there. I haven't noticed anything else wrong with this bitch so i'm not freaking out... ...should i be?
Old May 25, 2005 | 01:56 AM
rabthol's Avatar
Default RE: not a big deal but confused
May be a dumb question, but how is the coil lifting if it is secured by two bolts? Are the bolts missing?
Old May 25, 2005 | 09:07 AM
david9999's Avatar
Good question, All 4 coil packs are held in place by screws
and what happened to the engine cover too? I haven't even seen my coil packs in the last 30K miles
Old May 25, 2005 | 10:56 AM
dafrazi's Avatar
toastbiscuit, do you mean the boot on the spark plug wire that fits over the spark plug?
Old May 25, 2005 | 12:23 PM
CRAZYHAWK's Avatar
After the coils were replaced on my car , they put coils in without holddown screws.
Old May 25, 2005 | 02:07 PM
i didn't notice ant bolts or anyplace that they might go. I'm talking about the four little black square on top of your head that stare at you when you have that gay cover thing off. They seem to just be a pressure fit. I dunno
Old May 25, 2005 | 02:22 PM
skidplatexa4's Avatar
I know on mine the coil packs are held in place by 2 bolts. I believe on some of the newer ones there is a spring clip but I could be wrong.
Old May 25, 2005 | 02:33 PM
rabthol's Avatar
You year must be different, b/c on mine (1997 A4TQ) i have two bolts holding each of the coils down. There may be some sort of clip that is supposed to work in replacement of the bolts. Check the others. How are they held down? Can you take a photo?
Old May 25, 2005 | 03:45 PM
yeah so here's what those little shwaggers looks like. i dunno mabey i'm just gay.
Old May 25, 2005 | 06:06 PM
CRAZYHAWK's Avatar
Push them down with a little twist. The spark plug rubber boot will hold them in place.
