Not exciting. Changed DV and snub mount
Old Nov 14, 2004 | 09:44 PM
david9999's Avatar
Default Not exciting. Changed DV and snub mount
Changed the original DV to 710N. Engine growls more, not sure if there is a change in pickup. Interestingly, my car used to make a noise like a leaking tire when shut off but doesn't anymore.
Snub mount made a big difference, both good and bad. A lot more vibration at idle. Before, however, when I downshifted it felt like the engine moved about an inch under the chassis. Now it is quite tight.
Old Nov 14, 2004 | 09:52 PM
Jestnomen's Avatar
6th Gear
Default RE: Not exciting. Changed DV and snub mount
Which snub mount did you install? Usually if it vibrates it means it's not seated quite right.
Old Nov 15, 2004 | 07:18 AM
david9999's Avatar
APR
Old Nov 15, 2004 | 12:48 PM
brrman's Avatar
APR often requires trimming so that it is not making contack with its housing.
Old Nov 15, 2004 | 01:33 PM
sfordeso's Avatar
Man, how hard is it for them to just make the part fit right?
trevor51590
Feb 26, 2008 12:13 PM
milo55041
Oct 24, 2007 02:42 PM
jrock
Sep 2, 2007 07:00 PM
mjvss21
Feb 22, 2006 07:03 PM
b5 2 8
Jan 29, 2006 05:14 PM
