View Poll Results: A poll
Good
35.00%
Bad
10.00%
Don't Know
30.00%
Octane What?
10.00%
Useless
15.00%
Voters: 20. You may not vote on this poll
Is Octane Boost good or bad?
Old Feb 25, 2006 | 11:51 PM
activemonkey's Avatar
Default Is Octane Boost good or bad?
Is Octane Boost Good or Bad?
Why or Why not
Old Feb 26, 2006 | 12:06 AM
rbrtech's Avatar
Default RE: Is Octane Boost good or bad?
I use to run it in my rx7s but never realy noticed any diffrence just did it for safety reasons with the performance parts and tunning I was running
Old Feb 26, 2006 | 12:10 AM
Russ03A4's Avatar
At some point it is bad.
Higher octane makes a hotter burn in the cylinder. What's too hot? I don't know. If you use octane boost added to your tank, the actual rendered octane depends on what octane gas is in the tank, how much is in the tank and what the "boost" is that your adding to it.
There is a point where you're creating more heat than the engine components are designed for. Then the engine will fail sooner.
Run Sunoco 94 octane. You won't go wrong or find some 95 or 96 octane race gas and see if you really think that it's worth the performance gain.
I'd stay away from the octane boost. Too many variables.
PS - I'm not a professional mechanic but I have been an engineer for the past 25 years.
Old Feb 26, 2006 | 12:23 AM
avanttripleloop's Avatar
.some brands are good and some are crap.i notice some major increase when i use the brand +104 in my 2.8,but the same company's +108 turbo formula does not work well at all on my car.chevron techron is also good,and in my opinion chevron gas is the best there is around.i've done many tests on my 85 golf and they are safe,just mix correctly.
Old Feb 26, 2006 | 12:35 AM
actually it is better for your car because it is lowering the chance of preignition of weaker carbon chains in the gas.sounds smart huh but i just watched it on the history channels modern marvels and they talked about how they came up with the octane rating by volitivity of the gas before actual spark plug ignition.
Old Feb 26, 2006 | 12:39 AM
Russ03A4's Avatar
I wish I watched that show. 10 points to you!!
Old Feb 26, 2006 | 12:41 AM
headshok2002's Avatar
I didn't think higher octane burned any hotter... just LONGER... but I guess I wouldn't know.
Anyways, using octane boost is pointless... if you find yourself often searching for a gas station that sells premium (maybe you live somewhere far far away from civilization) then it is good to keep some octane boost with you, just to bring the octane up to over 91... but yeah, don't use it if you can already buy 91+
Old Feb 26, 2006 | 12:49 AM
i'd have drivin my subaru off a cliff if i didn't get to use octane boost,when i had that car. i wish we had over 91 here.try that +104,it's a kick.
Old Feb 26, 2006 | 12:57 AM
Russ03A4's Avatar
Check this link. Interesting stuff.
http://www.diabolicalperformance.com/hotrodoctane.html
Old Feb 26, 2006 | 12:58 AM
sandman's Avatar
yea, octane boosters are pointless if ur running the correct fuel. if you must use a regular fuel with a low octane this is when an octane booster is good.
