ode to the miles
Old Mar 8, 2005 | 12:28 PM
EXSupraMAN's Avatar
Default ode to the miles
I'D LIKE TO KNOW YOUR ODOMETER READINGS... AND AT WHAT MILEAGE DID YOU HAVE WHAT PROBLEM. I'VE ONLY HAD THE CAR A LITTLE WHILE AND I'VE GOT 109K, THE FUSE FOR THE RADIO BLEW(FIXED IT) AT NIGHT I CANT SEE 60MPH-120MPH/VOLTAGE ON THE GAUGE GUESSING BULBS BLEW JUST NOT WANTING TO DEAL WITH THAT MYSELF RIGHT NOW... AND IN THE MOURNING OR WHEN I START THE CAR FOR THE FIRST TIME IN THE DAY IT REVS HIGH AT ABOUT 1200 AND THE ENGINE MAKES THIS HIGH KNIFE SHARPENING NOISE FOR A FEW LIKE 50SECONDS THEN DROPS TO 800 AND SOUNDS FINE? BTW AT A GLANCE HOW DO YOU TELL THE DIFF BETWEEN A 12V AND A 30V... LOVE THE CAR SO FAR!
Old Mar 8, 2005 | 05:18 PM
BFlan's Avatar
Default RE: ode to the miles
you have a 98.5, yours is a 30V. the 12V stopped in 97. i have 138k on mine. just replaced the whole tranny, tie rod ends, cv joints, timing belt (should be done every 60k). the idling at 1200 i believe is normal, warm idling at 800 is definitely normal. the noise youre hearing i don't know, you'll have to be more specific. does it get louder as the engine revs? does it go away after a while? is it definitely coming from the engine bay? pop the hood and see if you can isolate the sound. it may be low power steering fluid, in which case the sound will get louder when you turn the wheel.
Old Mar 8, 2005 | 06:17 PM
audihere's Avatar
Banned
man bflan u shoulda did a 2.8 tranny swap if u just replaced ur tranny! o haha i just realized u do have a v6...nevermind
Old Mar 10, 2005 | 01:58 PM
EXSupraMAN's Avatar
the sound goes away after a minute when the car warms up... it sounds like a rusty fan knife sharping type comes from somewhere on the passenger side of the engine bay. it doesnt change with moving the steering wheel i'll pop the hood today and get down to specifics. thanks so far
Old Mar 11, 2005 | 11:51 AM
EXSupraMAN's Avatar
its coming from somewhere i cant see without lifting the car its lower passenger side behind black splash guard, sounds like something that needs oiling bad!
Old Mar 11, 2005 | 02:58 PM
BFlan's Avatar
supraman, sorry, i'm stumped. someone here should be able to give you some suggestions though.
Old Apr 9, 2005 | 12:34 PM
EXSupraMAN's Avatar
just hit 111111 and everythings crispy. the sound is a second air compressor that turns on when its cold and goes off in about 1 minute.
Old Apr 10, 2005 | 03:07 AM
Fieldy's Avatar
I got my car with 109 K
so far I changed the rear 02 sensors and MAF sensor and some ruptured lines. Oh and the rear window mechanism thing. About $800-$900 worth of stuff in less than a year; so maintenence is on the pricy side.
11AudiS5
Mar 17, 2013 04:16 PM
luxurycarsnw
Oct 23, 2009 03:13 AM
funcoland
Aug 20, 2009 09:02 AM
smtcapecod
Mar 6, 2007 05:30 PM
mvolps22
Jun 23, 2006 03:45 AM
