oil filter question???
Old Oct 19, 2006 | 08:05 PM
1234RiNgs's Avatar
Default oil filter question???
what would happen if i pull the filter out before draining the oil.
would this be bad.
might be a stupid quiestion but o well....
Old Oct 19, 2006 | 09:11 PM
Mike@PureMS's Avatar
Default RE: oil filter question???
Won't be any different.
Oil in the pan is in the pan.
Oil in the filter is in the filter. Doesn't matter which you remove first.
Old Oct 19, 2006 | 09:18 PM
TDRILL's Avatar
Yea your fine.
No worries.
Old Oct 19, 2006 | 09:24 PM
david9999's Avatar
Agree. no problem
Old Oct 21, 2006 | 01:34 PM
dankhound's Avatar
Its actually better to remove the filter first. It holds oil between the filter and the pan. When you replace the filter first, you remove more oil from the engine.
Old Oct 21, 2006 | 03:04 PM
Ford2Audi6's Avatar
its just going to be a lot more messy.
Old Oct 21, 2006 | 05:25 PM
TDRILL's Avatar
ORIGINAL: dankhound
Drain the pan. Then remove filter while plug for pan is still out. After everything is drained, then you put the plug back in and the filter on and then fill with oil. I don't think you get any more oil out of the engine by removing one before the other.
mikehinnenkamp
Aug 19, 2013 10:50 PM
A4 Jed
Jun 23, 2013 06:13 PM
ColoradoAudiDriver
Aug 29, 2010 12:04 PM
tool_462
Feb 20, 2008 11:16 PM
viper771
Mar 7, 2006 05:52 AM
