OIL LEAK FROM PASS. SIDE- WHAT IS IS?
...Just put the car up on the rack for an oil change, and noticed a leak coming from the back of the passenger side cylinder bank. It is seeping down the back of the block, onto the lower control arm. I checked behind the valve cover and it looks like its been burning off for some time. What is this leak, and can I DIY (moderate technical ability) or do you suggest taking it to a mechanic? 2.8 30v 113khere... any help woud be greatly appreciated.
You can do a valve cover gasket pretty easily if thats what it is. Best thing to do is degrease/power wash (carefuly) your engine and check for fresh leaks a couple days later.
ORIGINAL: manufan
Isn't there also a round plug on the back of the head?
I would just wash it all off then and use some-degreaser to get it off all the suspension/subframe componets and see if there is still oil present on the frame after a week or so. If so then change the rear cam plug/s.
