OIL LEAK FROM PASS. SIDE- WHAT IS IS?
Old Nov 18, 2007 | 07:24 PM
heloman28's Avatar
Default OIL LEAK FROM PASS. SIDE- WHAT IS IS?
...Just put the car up on the rack for an oil change, and noticed a leak coming from the back of the passenger side cylinder bank. It is seeping down the back of the block, onto the lower control arm. I checked behind the valve cover and it looks like its been burning off for some time. What is this leak, and can I DIY (moderate technical ability) or do you suggest taking it to a mechanic? 2.8 30v 113khere... any help woud be greatly appreciated.
Old Nov 18, 2007 | 07:27 PM
cincyTT's Avatar
I'm make believe
Default RE: OIL LEAK FROM PASS. SIDE- WHAT IS IS?
if its coming from the valve cover, it is the gasket. Change it and it will go away
Old Nov 18, 2007 | 07:29 PM
onepoint8tee's Avatar
You can do a valve cover gasket pretty easily if thats what it is. Best thing to do is degrease/power wash (carefuly) your engine and check for fresh leaks a couple days later.
Old Nov 18, 2007 | 07:32 PM
manufan's Avatar
Isn't there also a round plug on the back of the head?
Old Nov 18, 2007 | 07:36 PM
ORIGINAL: manufan
[sm=WTFsgign.gif]
Old Nov 18, 2007 | 07:37 PM
hiwords's Avatar
are u talking bout the cam postion sensor?
Old Nov 18, 2007 | 07:51 PM
manufan's Avatar
If you drop a mirror down behind the passenger side head, there is a round rubber/plastic plug. Mine is leaking and it drips right on the manifold.
Old Nov 18, 2007 | 08:06 PM
auditech79's Avatar
ORIGINAL: manufan
Thats a cam plug, those are easy to change but hardly ever leak. Most likely the leak is the cam tensioner gasket (half moon seal)
Old Nov 18, 2007 | 08:12 PM
manufan's Avatar
Supposedly the dealer changed the cam tensioner gaskets shortly after I bought the car. I'm hoping that isn't it. I noticed it from below when I was changing control arms.
Old Nov 18, 2007 | 08:15 PM
auditech79's Avatar
I would just wash it all off then and use some-degreaser to get it off all the suspension/subframe componets and see if there is still oil present on the frame after a week or so. If so then change the rear cam plug/s.
