oil leak w/ estimate
Okay so apprently my car is leaking oil, they put the dye in and checked for the leaks and this is the dealership estimate that i got:
Requires repair: oil cooler Valve cover gasket Front cam seals P.C.V. clean up PARTS (APPROX.- $ 180 + 8.0 HOURS OF LABOUR- $800.00) Parts: 058-198-025-A Gasket set 50.64 058-103-213 Tube 44.78 N-904-673-01 Seal 3.20 N-905-618-01 Clip (2 x 2.00) 4.00 06A-103-247 Housing 9.38 N-102-581-01 Clip 2.25 035-103-245-A Valve 20.30 N-102-555-01 Clip 1.50 068-103-085-E Seal 8.64 038-117-070-A Washer 5.48 Any suggestions as to what I should do? How easy would this stuff be to do myself considering I have fairly low experience? |
RE: oil leak w/ estimate
I did the cam tensioner gasket and valvecover gasket in about 2 hours on a longitude engine, cost $40 in gaskets and $25 for cam tool.
Never had to mess with the oil cooler. PVC should be somewhat easy to clean. If you can do the two gaskets, that would cut off $400. |
Any online tutorials or guides for this stuff for a 97 1.8t?
http://passat.wikispaces.com/
http://www.taligentx.com/passat/main...vecovergasket/ these should help. if you mark the camslike in the links, your fine. The cam gasket if you just undo the 3 screws you can slide it out without going to crazy on the intake cam. |
If you need to have the front cam seals done - that requires you to remove the front of the car. It just like doing the Timing belt job(look at audidiy.com for a DIY). Are you handy with a wrench - I'm ok with working on cars and I did this job a few weeks ago. Find all the parts you need at ECStuning.com or purems.com. everything on your list you should be able to do over a saturday.
I've done a few simple things with the car (changing brake pads, wheel bearings) and I don't mind trying something a little more complicated but I just dont want to get into doing anything that I could really mess up and destroy the engine or something like a timing belt job and I also prefer to work around the car not underneath it seeing as I'd be working in my garage and just have those simple little supports to hold the car.
| All times are GMT -4. The time now is 02:26 AM. |
