oil leak w/ estimate
Old May 9, 2007 | 03:34 PM
sheek's Avatar
Default oil leak w/ estimate
Okay so apprently my car is leaking oil, they put the dye in and checked for the leaks and this is the dealership estimate that i got:
Requires repair:
oil cooler
Valve cover gasket
Front cam seals
P.C.V. clean up
PARTS (APPROX.- $ 180 + 8.0 HOURS OF LABOUR- $800.00)
Parts:
058-198-025-A Gasket set 50.64
058-103-213 Tube 44.78
N-904-673-01 Seal 3.20
N-905-618-01 Clip (2 x 2.00) 4.00
06A-103-247 Housing 9.38
N-102-581-01 Clip 2.25
035-103-245-A Valve 20.30
N-102-555-01 Clip 1.50
068-103-085-E Seal 8.64
038-117-070-A Washer 5.48
Any suggestions as to what I should do? How easy would this stuff be to do myself considering I have fairly low experience?
Old May 9, 2007 | 03:46 PM
cincyTT's Avatar
I'm make believe
Default RE: oil leak w/ estimate
I did the cam tensioner gasket and valvecover gasket in about 2 hours on a longitude engine, cost $40 in gaskets and $25 for cam tool.
Never had to mess with the oil cooler. PVC should be somewhat easy to clean. If you can do the two gaskets, that would cut off $400.
Old May 9, 2007 | 03:49 PM
sheek's Avatar
Any online tutorials or guides for this stuff for a 97 1.8t?
Old May 9, 2007 | 03:57 PM
cincyTT's Avatar
I'm make believe
http://passat.wikispaces.com/
http://www.taligentx.com/passat/main...vecovergasket/
these should help. if you mark the camslike in the links, your fine. The cam gasket if you just undo the 3 screws you can slide it out without going to crazy on the intake cam.
Old May 9, 2007 | 04:14 PM
akielb's Avatar
If you need to have the front cam seals done - that requires you to remove the front of the car. It just like doing the Timing belt job(look at audidiy.com for a DIY). Are you handy with a wrench - I'm ok with working on cars and I did this job a few weeks ago. Find all the parts you need at ECStuning.com or purems.com. everything on your list you should be able to do over a saturday.
Old May 9, 2007 | 04:26 PM
sheek's Avatar
I've done a few simple things with the car (changing brake pads, wheel bearings) and I don't mind trying something a little more complicated but I just dont want to get into doing anything that I could really mess up and destroy the engine or something like a timing belt job and I also prefer to work around the car not underneath it seeing as I'd be working in my garage and just have those simple little supports to hold the car.
Lizzard
Oct 30, 2008 11:14 AM
quattrolove
Apr 4, 2008 01:06 AM
USAF29
Jul 16, 2007 09:10 PM
apg96
Apr 11, 2005 04:40 AM
