OIL light a4 b5 1.8 1996 HELP
Old Jul 19, 2007 | 06:41 AM
TagsAudi's Avatar
Default OIL light a4 b5 1.8 1996 HELP
Hi everyone,
Went to start the car this afternoon and as it started 'OIL' showed up on the dash displayit stayed on for about a minute then went off. i checked the oil level and it wasnt low. What else could this be?Needs an oil change? oil pressure?
Car still runs fine.
thanks guys
Old Jul 19, 2007 | 09:52 AM
wood_e's Avatar
Default RE: OIL light a4 b5 1.8 1996 HELP
Pressure - low or a bad switch. Check for sludge...
Old Jul 19, 2007 | 01:11 PM
david9999's Avatar
As above
Old Jul 19, 2007 | 01:47 PM
onepoint8tee's Avatar
Stop driving it till you figure it out either way.
Old Jul 19, 2007 | 01:52 PM
auditech79's Avatar
Wait you have a 96 A4, that just has the idiot lights in the cluster, was the light illuminated on the bottom right hand corner of the cluster? If it was it could be just the oil change light, my buddies does that too but hes too lazy to hook it up to the VAG COM to change it, the older models have to be changed with a scanner.
Old Jul 19, 2007 | 02:11 PM
wood_e's Avatar
good call! if it's flashing oil on your trip mileage then you're ok
Old Jul 19, 2007 | 08:42 PM
TagsAudi's Avatar
yeh the OIL appears under the trip meter, flashes on and off for about 1minute then goes off
Old Jul 19, 2007 | 09:49 PM
auditech79's Avatar
ORIGINAL: TagsAudi
If thats the case take it to the dealer and get the service reminder re-set, or if it doesn't bother you ignore it.
Old Jul 20, 2007 | 02:42 AM
wood_e's Avatar
We're so used to associating oil and 1.8t sludge around here....
Old Jul 20, 2007 | 02:53 AM
ORIGINAL: wood_e
Man, I bet you live for these moments when you get to take a 1.8t jab,dont you?
Sad, but true though..... Actually its been a while. I think the giplantic oil filter and use of full synthetic oil is making a difference in the world..
