oil light came on, engine starting clicking
Old Oct 7, 2007 | 02:23 PM
jeffblake's Avatar
Default oil light came on, engine starting clicking
the oil light came on in my 2004 audi a4 and then the engine started clicking badly
Old Oct 7, 2007 | 02:24 PM
jeffblake's Avatar
Default RE: oil light came on, engine starting clicking
engines started clicking when oil ligh came on, just had oil change
Old Oct 7, 2007 | 02:25 PM
techbod's Avatar
low oil level did you check it?
Old Oct 7, 2007 | 02:28 PM
jeffblake's Avatar
added 2 quarts yesterday just to make sure and the oil level is fine.
Old Oct 7, 2007 | 02:33 PM
techbod's Avatar
and??
Old Oct 7, 2007 | 02:35 PM
jeffblake's Avatar
Oil ight keeps coming on, says to turn off engine and check oil, egnine knocking very badly between 1000 and 2000 rpm.
Old Oct 7, 2007 | 02:39 PM
techbod's Avatar
oil pump sorry to say but its common
Old Oct 7, 2007 | 02:41 PM
jeffblake's Avatar
can i drive it to the shop? and how expensive are they to replace?
Old Oct 7, 2007 | 02:45 PM
onepoint8tee's Avatar
Dont drive it. Its either sludge on the pickup screen in the oil pan,or a bad oil pump. Either way, once you get in to replace one, you should replace the other. Get a flatbed. Probably not cheap with the labor, but a lot less than a new engine if you wait/try to drive it.
Old Oct 7, 2007 | 02:48 PM
jeffblake's Avatar
if i take it to a audi dealer, how long does it take to fix? think it would be under a $1,000. to fix
