oil light and stalling
Old Aug 26, 2007 | 04:03 PM
onepoint8tee's Avatar
Default RE: oil light and stalling
crankshaft position sensor.....................?
Old Aug 26, 2007 | 04:05 PM
auditech79's Avatar
There is only one little screw holding the crank position sensor, but what do i know.
Nicks A4's Avatar
camshaft position sensor.
theres 2 bolts holding it on
Old Aug 26, 2007 | 04:08 PM
auditech79's Avatar
Now that does have two bolts holding it on, but that won't cause it to stall on our engines. It will throw a fault like you say but it will just run like a KIA most likely. I believe the engine will run with it disconnected.
Old Aug 26, 2007 | 05:35 PM
Nicks A4's Avatar
well it was running like crap before it stalled
Old Aug 26, 2007 | 05:39 PM
auditech79's Avatar
I would imagine it would with no oil pressure, do not run the motor with the oil light on! Once the oil pick up tube gets clogged it doesn't take much to take out the motor. Your first order of buisness is to get the oil pressure checked, then worry about the rest.
Old Aug 26, 2007 | 11:38 PM
Nicks A4's Avatar
well without the car being able to start how could i check the oil pressure
Old Aug 26, 2007 | 11:44 PM
  #18
acetrebo's Avatar
Ok, you say your a technician, did you check the engine codes its throwing to see whats going on?
Or are there none?
If it was running like crap before it died, it sounds like you were having a timing or misfire problem if the engine and oil temps were normal.
Old Aug 27, 2007 | 10:15 AM
  #19
Nicks A4's Avatar
yes i scanned it.
CPS code.. didnt i say that in here?
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 8D0 907 557 N
Component: 1.8l R4/5VT MOTR AT D03
Coding: 06251
Shop #: WSC 06335
1 Fault Found:
17746 - Camshaft Position Sensor (G40) Open or Short to Plus
P1338 - 35-00 - -
Readiness: 0000 0100
Address 02 -------------------------------------------------------
Controller: 8D0 927 156 T
Component: AG5 01V 1.8lR4T US D06
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 03 -------------------------------------------------------
Controller: 4D0 907 379 L
Component: ABS/EDS BOSCH 5 4171
Coding: 0265109043
Shop #: BB 34171
No fault code found.
Address 08 -------------------------------------------------------
Controller:
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 919 036
Component: B5_KOMBIINSTRUMENT D10
Coding: 00242
Shop #: WSC 06335
Address 35 -------------------------------------------------------
Controller: 8LO 862 257 B
Component: CV-Pump,Alarm, RC
Coding: 12172
Shop #: WSC 65535
8 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01373 - Alarm triggered by Radio Ground Contact
35-00 - -
End -------------------------------------------------------
Old Aug 27, 2007 | 03:11 PM
  #20
acetrebo's Avatar
It looks like the CPS threw a code.
Either the sensor is bad, or the harness connector is not making a good connection.
Start there, by cleaning the harness. Then clear the codes, try to start the car, and see if a CPS codes comes back.
I would clear by pulling the negative battery cable, to reset the ecu.
