oil pump
Old Jul 14, 2006 | 03:05 AM
budnfrida's Avatar
Default oil pump
i am guessing that it is the oil pump or oil cooler the the oilfilter screws into. my question is. Is it a 2 part unit because there is a leak that looks like it is coming from where it connects the the engine. it there a gasket between the 2 parts? or if not can i just put some jb weld on it to seal it? leak is where the arrow is.
[IMG]local://upfiles/20259/D713023A47F542908B2FA99AD59BEB6E.jpg[/IMG]
Old Jul 14, 2006 | 03:46 AM
techbod's Avatar
Default RE: oil pump
there is a gasket in there mate remove that nut in the middle and the unit splits in two and fit a new gasket
Old Jul 14, 2006 | 01:38 PM
budnfrida's Avatar
So it should be a pretty cheap part from the dealer then. so will i have to drain all my oil to change it or just the oil filter and do i need a new oil filter because the one i have on is less then a month old.
Old Jul 14, 2006 | 01:50 PM
brrman's Avatar
You'll want to drain it all. Do it right.
Old Jul 14, 2006 | 02:58 PM
budnfrida's Avatar
thanks for the info
jsethwerner225
Nov 14, 2014 01:55 PM
MetalMan
Jul 19, 2012 09:15 PM
Sardor
Sep 7, 2010 06:02 PM
Deanne
Feb 6, 2008 05:45 AM
