Ok im buying a gt28rs
Old Oct 23, 2007 | 09:47 PM
  #81
Kyle09's Avatar
Default RE: Ok im buying a gt28rs
k i would back that up if you can, because cincy is going to ****..and at this point i dont know who to believe..im just going to believe my mechanic friend.
Old Oct 23, 2007 | 11:29 PM
  #82
cincyTT's Avatar
I'm make believe
ORIGINAL: sean1.8t
for the 500hp melting a piston, yes, i have not seen it on a healthy engine(seen plenty burn up running lean, but at all power levels). im just going off of what is recomended by previous BIG hp 1.8t makers. and the manufactures
How can you say the pistons are at fault when the tune is lean? Thats not a power problem, thats a heat problem. You might aswell just shoot the EGT'S skyrocketing and blame thepistons also.
andtorque breaks driveline parts (axles/transmissions/shifterlinkage/etc..) Right, but thats not the dicussion.
high hp + high reving + heat = broken rod Again, TQ, low end in fact, BREAKS RODS!! Thats why people with a gt2871r .64 are FAR more at risk to snap a rod than those running a .86. Low tq and a smooth transition to TQ makes it easier on the rods, no matter the HP. Thats what makes a gt2871r .86 and a t3t4 50trim .63 such great turbos for stock rods. You can make 350whp+ and still be on stock rods. There is a person with a 2000 TT making just under 400whp on stock 20mm wrist pin rods on a gt2871r .86
there is more stress on a rod with a motor spinning at 7000rpms making 200whp than there is on a rod when the motor is spinning at 4000rpms making 500wtq..
You are high, arent you? You are more likely to spin a rod bearing at 7k, but not break a rod
i forget the math, but every x amount of rpms you rise, the stress on the rods increses 10 fold. i'll see if i can look it up Do what you like, your still wrong
Old Oct 23, 2007 | 11:30 PM
  #83
cincyTT's Avatar
I'm make believe
FYI, 20mm wrist pin rods (97-99.5)should be changed when you start to approach 320wtq and (200+) 19mm wrist pin rods should be changed once clearing 300wtq.
Old Oct 23, 2007 | 11:44 PM
  #84
cincyTT's Avatar
I'm make believe
Stock pistons have made over 700chp by Bob Q @qed. And if you read the last post, Lugnuts (tuner making over 500whp on a gt30r and now just under 700whp on edsgti) taking about bad...... wait for it......SW burning up pistons.
LINK
Old Oct 23, 2007 | 11:46 PM
  #85
A4speed's Avatar
ok, so did he officially decide what kit he was going to buy yet?
  #86
cincyTT's Avatar
I'm make believe
Again, more USEFUL info
Old Oct 24, 2007 | 01:06 AM
  #87
Kyle09's Avatar
http://www.atpturbo.com/Merchant2/me...ory_Code=VVWTK
There she is^^
Old Oct 24, 2007 | 01:21 AM
  #88
chaos92287's Avatar
[quote]ORIGINAL: cincyTT
ORIGINAL: sean1.8t
^actually no, the AEB's internals are not forged. that was speculation for a long time.
No rods are forged, just pistons.
umm...there are definitely forged rods
Old Oct 24, 2007 | 02:02 AM
  #89
BARRY's Avatar
cincyTT, shut up. you always seem to think you know everything.
the torsional load from the back and forth motion of a engine spinning at 7000rpm is tons(weight) in difference than a similar engine at 4000rpm.
RPM kills motors most of the time, not power. you blow a motor at low rpm due to bad tuning.
spinning a bearing or throwing a rod is fault of inconsistant oiling to the bearing. OR an obsurd amount of knock in which the force of the knock caused the bearing to have metal to metal contact.
or...a spun bearing can happen from over rev in which any number of things could have been the cause.
Old Oct 24, 2007 | 02:05 AM
  #90
BARRY's Avatar
OHHH by the way...power doesn't break rods. its knock or the bearing seizing up from metal to metal contact.
