OMG Turbo lag no more!!
So I finally got a little time today so I went an hooked up and partially tuned the anti-lag thats a feature on the 034efi standalone...WOW I can hit full boost at 2000rpm if I set it there, not only that, its also loud as all hell. Boost makes my exhaust valve open so I have straight 3" exhaust dumping under the car
Basically this is what rally cars use, you go into a corner and instead of lifting off the gas, you hold down the anti-lag button, and the ecu cuts back timing soo much that the car makes no power, but it loads up the motor creating boost. The gas combusts very late in the cycle., ones your ready to get on the gas coming out of the corner, you let off the switch and your immediatly at full boost, with normal timing. Anyways its fun and I had to share..next up, launch control..full boost without moving, whatever rpm i want
Jesus Mother of GOD!!!! Tom.. we need to get you sponsored seriously!!! Are you planning on making this a race car anytime soon??
EDIT: When is the Vid coming?? I will freaking lend you my camcorder if you need it!!
ORIGINAL: miked
Damn, thats crazy. Thats a huge accomplishment, and a huge leap forward in A4 terms. Have fun.
Ahahha I wish I could get sponsored...bigger turbo planning has begun and I'm at school and things are starting to get boring so a new video will be coming sometime in the near future. I have ALOT of loose ends to tie up before h20 so I will be busy for the next couple weeks. H20 International in OC MD will be the first time I have showed my car
Na its gonna be my daily driver so not gonna be a race car
I prolly should mention that the egt's get extremly high so its not like I can use this everytime I drive otherwise Id be replacing manifolds and turbo pretty often, but for the fun runs and such, its great. Now i gotta learn how to properly use it
Right now I just have it on the end of a wire, I geuss rally cars would have it on the steering wheel like u said, I will prolly have mine on the end of a coil coard similar to a coiled telephone wire
