which one Ko4 or this........
Old Oct 18, 2005 | 12:25 PM
  #21
juju4uofa's Avatar
Default RE: which one Ko4 or this........
Thanks, that's what I thought. I found a guy who says he can getme a deal on a Ko4. Apparently he does a lot of turbo work on Honda's. Hopefully he'll know what I mean by a K04-015
Old Oct 18, 2005 | 12:31 PM
  #22
99A4NOW's Avatar
Where or what it is a good source for information on turbo upgrades for the A4 that would be helpful for the completely ignorant like me. You guy are confusing the hell out of me with all this turbo lingo about different programs and stuff... I'd love to be able to sort it all out. I'm not a serious modder (yet) but I think I am in need of an upgrade in power. My car seems to run ok, but I have not compared it to anything else yet, what it the life expectency of the stock turbo? I'm wondering if I need to start my upgrades with that first...
Old Oct 18, 2005 | 01:07 PM
  #23
juju4uofa's Avatar
You can find quite a bit on info on forums themselves. Look on here, Audi World, Audi Zine, and others for info. Most people who upgrade their turbo go with either a K04 (this is the turbo found on the 225hp version of the Audi TT), some version of a T3/T4 turbo, or a Garret turbo. When you see BT it means Big Turbo typically refering to a Garret or the T3/T4. The advantage the Garrets have over the others is the fact they are ball bearing. This allows them to spool quicker and smoother and also them to produce boost at higher rpms than non-ball bearing turbos. When upgrading your turbo you'll also need to upgrade your fuel supply by replacing your injector and FPR (Fuel Pressure Regulator) with the appropriate sizes (the normal "non-aggressive" software for the K04 does not require injectors). It is also a good idea to replace your Intercooler and exhasut when upgrading turbos. Both of these will allow the entire system to run smoother and the exhaust will allow the turbo to spool much quicker therefore producing more power. This only scratches the surface of turbo upgrading but hopefully it'll help. you can also take a look at the links stickied at the top of the "Audi A4" forum to learn about the individual suppliers and their products.
Old Oct 18, 2005 | 01:43 PM
  #24
quattrosedan's Avatar
yeah I was like WTF!!! when I talked to him. He said he had a fully built tranny by stasis, stg 4 clutch, and was about to do some t3/t4 to get into the low 12s or something. I wish I would have got his number, he seemed like a pretty intelligent guy.
Old Oct 18, 2005 | 09:53 PM
  #25
aaronamericahall's Avatar
so it looks like the KO4 is the way to go, but what is pc16 software is that by GIAC and whats the specs on the pc16 and any other programs they make for the KO4 for the b5
Old Oct 18, 2005 | 10:17 PM
  #26
audiboy1618's Avatar
Pc-16 is Giacs most aggressive file for the ndbw. It runs 18psi and lots and lots of timing. Makes lots of torque. Prolly close to 340 to 350 on sauce.
Old Oct 19, 2005 | 03:26 AM
  #27
Yuikio's Avatar
ORIGINAL: audiboy1618
Yukio, theres a solution for ndbw bt software. Its called apr stage 3, and pes t28. Thats where its at.
Well yeah, but there's another solution for slow A4s...buy an S4 and STG III that. Or get your 1.8T bored, and stroked, put in race cams, a super-heavy-duty crank, aftermarket pistsons and rods, and put a GT42 on a Fullrace.com mani. The only obstacle is money.
I mean, APR and PES are obviously the two big ones, but pretend you wanna go bigger than a T28, or you don't want to pay $4500 for a turbo kit even though you're assured of its results. I mean, aren't you trying to piece together your own APR Stg III kit? Didn't you just post about getting raped by APR on their software?
I guess I meant besides those two. Besides the expensive kits, or custom dyno tuning, there's no single solution to nDBW BT software.
Old Oct 19, 2005 | 03:54 AM
  #28
nice so KO4 and the pc16 file it is
Old Oct 19, 2005 | 09:04 PM
  #29
Yeah, my whole apr kit was only a few hundred less then the advertised price, but mine is a faster setup too.
Old Oct 19, 2005 | 11:47 PM
  #30
duhvinci's Avatar
Is it true that PC16 file is not for AEB? If so, what is the next best thing for AEB/KO4 upgrade (chip wise)?
Thanks,
D
