only 4lbs of boost???
Old Sep 20, 2007 | 09:07 PM
Bondga's Avatar
Default RE: only 4lbs of boost???
ORIGINAL: cacaro
so the benefits of a fmicare none if you dont have ridiculous amountsboost?
no you dont need a ridiculous amount of boost, but the k03 flows about as much air as your standard hair dryer.
Old Sep 20, 2007 | 09:18 PM
kemp_travis's Avatar
get an MBC and turn in up until it hits stock boost on your gauge....my buddy did the same thing with is 1.8 jetta.
noone thinks his N75 is bad?....and you dont have the blow off valve on atmospheric do you?
Old Sep 20, 2007 | 09:22 PM
Bondga's Avatar
that could work but will change the driving characteristics of ur car
Old Sep 20, 2007 | 09:27 PM
cacaro's Avatar
the blow off is 50/50 and my n75 is new but stock.
Old Sep 20, 2007 | 09:29 PM
Bondga's Avatar
n75 isnt your problem, bov only effects boost levels if its broke, its your fmic or a leak
Old Sep 20, 2007 | 09:31 PM
wellll ive heard that when the bov is 50/50 it will limp out...
try 70/30
but get a MBC
Old Sep 20, 2007 | 09:33 PM
Bondga's Avatar
ORIGINAL: kemp_travis
try 70/30
but get a MBC
noooo...... you only go into limp when you run lean, BOV causes rich. just chip it and the drop will still be there but far less
Old Sep 20, 2007 | 09:40 PM
  #18
cacaro's Avatar
im going bt, im currently looking for the best power and reliability option, i want something better than a k04.
Old Sep 20, 2007 | 09:41 PM
  #19
do u have yur boost gauge hooked up to the fpr vac line?
well my buddies jetta limped out when he went 50/50...
get MBC...hah
Old Sep 20, 2007 | 09:42 PM
  #20
wht does bt mean...i have an idea...but dont wanna sound like a jackass
