Only Some Vents Work..
Old Oct 27, 2007 | 11:30 AM
96A4Owner's Avatar
Default Only Some Vents Work..
The other day my vents for heat in my dash completely stopped working, but the windshield vents and the vents near my feet still work. I was thinking it might be a fuse but then again i dont know s*it about cars. Any help would be appreciated. Thanks in advance.
Mike
Old Oct 27, 2007 | 11:38 AM
hiwords's Avatar
Default RE: Only Some Vents Work..
u kno there are buttons that control which ones they come out of right?
Old Oct 27, 2007 | 03:54 PM
96A4Owner's Avatar
Yes, i tried them all, but they still don't work. And winter's coming up fast, i live in MI so i need some help asap.
Old Oct 27, 2007 | 04:34 PM
Jits7's Avatar
got the same prob...
Old Oct 27, 2007 | 04:42 PM
hiwords's Avatar
my guess is either the climte control or the mechnical part of the vent. pm auditech79, he can tell u more specifics on it
Old Oct 27, 2007 | 05:39 PM
auditech79's Avatar
Is the a/c control head stuck in econ?
Its probably either a bad a/c control head or flap door like hiwords said.
Old Oct 28, 2007 | 03:36 PM
96A4Owner's Avatar
What is econ, is it the little icon that looks like a snowflake? And just to let you guys know my air conditioning doesn't work too if that means anything. I think it's the compressor.
Old Oct 28, 2007 | 08:17 PM
96A4Owner's Avatar
Need some help here, Michigan gets pretty cold so any help would be appreciated.
Old Oct 28, 2007 | 10:20 PM
auditech79's Avatar
If your a/c isn't working its stuck in econ mode, take it to the dealer or use a VAG COM to check the fault codes in the a/c control head. If the a/c system is out of refrigerant (from a leak) it will shut the a/c system into like a limp mode that only lets you do a couple of things.
You have to get the fault codes checked.
Old Oct 29, 2007 | 03:01 PM
96A4Owner's Avatar
it's not the ac i'm worried about though, it's the heat, does the ac control head control the heat too?
