Operation: Blue Smoke *URGENT*
Old Jan 7, 2005 | 02:32 AM
CaliA4's Avatar
Default Operation: Blue Smoke *URGENT*
So I ve been told that blue smoke is a sign that the car is burning oil. Is there anyway to fix this and how much would it cost? Also while we are on the topic of smoke, what does white and grey smoke signify? (This is all on a 96 A4 2.8QT with 120K miles.)
Thanks for the help,
Mike
Old Jan 7, 2005 | 03:01 AM
CaliA4's Avatar
Default RE: Operation: Blue Smoke
I just got this car, had it checked out and it passed smog....
Old Jan 7, 2005 | 11:31 AM
Jestnomen's Avatar
6th Gear
White smoke is usually coolant burning. It will usually smell sweet to. Dude go get your car look at by a mechanic, or take it back to the place you bought it. You are goign to have bigger problems if you don't. As far as costs, there is no way to tell. There is no way to diagnose this problem over the internet for certain.
Old Jan 7, 2005 | 05:05 PM
CaliA4's Avatar
Called the Audi mechanic. They told me that that is not unusual in the colder weather we've been having (40-51 degrees F) and I just had a compression test done last week and everything was fine so its no use to worry I guess.
Old Jan 7, 2005 | 05:26 PM
Jestnomen's Avatar
6th Gear
Umm... That sounds fishy to me.
Old Jan 7, 2005 | 05:31 PM
JDCrowe's Avatar
yeah, keep "guessing" that is's nothing serious, and dont be upset when you find out that it was.
i live in Philly and it gets alot colder here than in SoCal..... and my Audi has NEVER blown out blue smoke!
take your car to a mechanic, if your honestly concerned about it.
whatever it is, it'll cost less to fix now than it will when it gets worse.
Old Jan 7, 2005 | 05:42 PM
CRAZYHAWK's Avatar
There could be oil mixed with the gas. Run another tank of gas to see if it clears up.
Old Jan 7, 2005 | 07:09 PM
Jestnomen's Avatar
6th Gear
Well yeah it's pretty obvious there is oil mixing. But just waiting to burn another tank of gas isn't goign to make the problem go away.
Old Jan 7, 2005 | 07:11 PM
audiboy1618's Avatar
Where i am 41 and 50 degrees is extremly warm for now, its like 10 most of the time and my car never does that.
Old Jan 7, 2005 | 07:29 PM
Jestnomen's Avatar
6th Gear
Yes, under NO circumstances is burning enough oil to be visable "Normal".
