'P R N D' lights flashing - codes appear & reverse fails
Hello All,
I need some help 'Please'. I drive an A4 (2004) sedan 2.0 and the other week I hit an issue. When I turned the car on the 'P R N D ' lights went all red and began to flash on the dash. :eek: Then we I put the car into 'R' the R light didn't light up and there was no power in the reverse. The next day everything was fine. It happens once approx 10% of the time I start the car. I then went to my local garage and he scanned it for me. The following appeared: ================================================== ==================== Engine: 17887 - Brake Boost Vacuum System: Mechanical Failure Gear Box: 18201 - Trans Output Speed Sensor 2 ( G196) No signal -> Part 1793 - Output Shaft Speed Sensor Signal Missing Sensor 2 17090 - Tran Range Sensor ( F125) Implausible Signal -> Part P0706 Inhibitor Switch, Range Signal Out of Range ** We cleared the codes waited for it to re-occur and the same 3 codes appeared on a re-scan ** ================================================== ============================== My question is: Which part/sensor should I be purchasing to attempt to fix this issue and what should be the approx price? My mechanic said his happy to fix however I need to provide him with the correct part and instruction may help. I called Audi and they said to ignore those codes...they will need to rescan and diagnose themselves $300. Great!!! I'm made of $$$ :mad: Any help would be unreal. :confused: Cheers David |
