'P R N D' lights flashing - codes appear & reverse fails
Old Feb 26, 2009 | 06:14 AM
dvespa's Avatar
Default 'P R N D' lights flashing - codes appear & reverse fails
Hello All,
I need some help 'Please'.
I drive an A4 (2004) sedan 2.0 and the other week I hit an issue.
When I turned the car on the 'P R N D ' lights went all red and began to flash on the dash.
Then we I put the car into 'R' the R light didn't light up and there was no power in the reverse.
The next day everything was fine. It happens once approx 10% of the time I start the car.
I then went to my local garage and he scanned it for me.
The following appeared:
Engine:
17887 - Brake Boost Vacuum System: Mechanical Failure
Gear Box:
18201 - Trans Output Speed Sensor 2 ( G196) No signal
-> Part 1793 - Output Shaft Speed Sensor Signal Missing Sensor 2
17090 - Tran Range Sensor ( F125) Implausible Signal
-> Part P0706 Inhibitor Switch, Range Signal Out of Range
** We cleared the codes waited for it to re-occur and the same 3 codes appeared on a re-scan **
My question is:
Which part/sensor should I be purchasing to attempt to fix this issue and what should be the approx price?
My mechanic said his happy to fix however I need to provide him with the correct part and instruction may help.
I called Audi and they said to ignore those codes...they will need to rescan and diagnose themselves $300. Great!!! I'm made of $$$
Any help would be unreal.
Cheers
David
dvespa
Nov 3, 2016 10:18 AM
craigsheehan
Jan 28, 2012 04:04 PM
DPTS
Aug 10, 2011 01:42 PM
kbayern
Apr 26, 2011 03:36 PM
mshprojects
Sep 1, 2008 07:01 PM
