p0302 cylindr 2 misfire 1.8t 99 a4
Old Sep 14, 2007 | 08:02 PM
andrew4g63's Avatar
Default p0302 cylindr 2 misfire 1.8t 99 a4
so my audi startedmissing today and threw a p0302 code. so i figured it was the coil so i repaced it along with all the plugs. put it all back together and have the same problem. it will idle like it barely running and going to die and then when you drive it barely drives also. anyone have suggestions to what would be wrong
Old Sep 14, 2007 | 09:27 PM
rally2's Avatar
Default RE: p0302 cylindr 2 misfire 1.8t 99 a4
P0302Cylinder 2misfire Detected
I had the same problem too...turned to be the ICM
If you replaced your packs and the results are the same I would say replace the ICM.
It's located on top of the air box.
Old Sep 15, 2007 | 07:35 AM
david9999's Avatar
Cyl 2 is most likely ICM. Swap coils and spark plug and clear the codes. If the misfire stays on cyl 2, it is the ICM.
Old Sep 16, 2007 | 10:39 AM
ggggrant's Avatar
I just had the same problem, same car. it was the ICM.
green2man0
Oct 22, 2014 09:53 AM
n_gunjan
Sep 23, 2013 11:42 AM
Race515facE
Feb 19, 2010 04:20 PM
Steve2008
Aug 4, 2009 09:40 AM
dhypnotized
Mar 30, 2008 03:40 AM
