which performs better 17s or 18s and which rims look better??
which of the two would you perfer if buying new rims in the spring time? What do u guys think handles better 17s or 18s? i hear the bigger the better but i would think too big would obviously be bad. I wanna get some low profile tires as well. the two rims i have in mind are rials or these http://www.tirerack.com/servlet/Call...filterSpecial=
oops first link didnt work here it is again http://www.tirerack.com/servlet/Call...filterSpecial=
None of the links work. 17s are best performance wise, but 18s would look better because they would fill more of the wheel well. If pot holes are a problem where you live, that's another reason to go 17.
+1 man i mean its obvious that 17's will performe better, less rolling distance and less mass is better for acceleration and all, but 18's deff look better
ORIGINAL: impaler2383
The bigger the rim size the more top speed you will have, and worse your brakes will be. Not to mention the 18's are more expensive and will likely be messed up if you hit a pothole because the tire has to be really thin. But its your car and everyone has theor own opinion of what they like. I have have 17's on my car and they fit real nice.
I would say 18's would perform better. Better handling. As far as less rolling distance that depends on what tire you are running. Personally 18's are the way to go on all accounts IMHO.
Acceleratoin wise, go with the 17's. Just get a lower profile and wider tire for better handling.
18's for the look. Unless you're pushing 300hp.
