Perormance
Old Oct 2, 2006 | 04:22 PM
Robsa4's Avatar
Default Perormance
I have a 2000 a4 1.8t quattro, how much difference would it make if i just put a ko4 turbo on it without any other modifications, with a chip?
Old Oct 2, 2006 | 04:30 PM
A4speed's Avatar
Default RE: Perormance
A good noticable one maybe....
Old Oct 2, 2006 | 04:38 PM
DENIS415's Avatar
Stage 1 KO4 setup gives you about 70whp and performance is dependent on whether you have drive by wire or non drive by wire. You may need to upgrade to better DV, get a FMIC, and a full flow exhaust system.....the cost of the KO4 is about $5000....i would rather just chip it because you get a 40-50hp gain for about $500....saves you money.....but if you want the KO4 you will def. feel power, raw power!
Old Oct 2, 2006 | 04:45 PM
smokeU's Avatar
I agree chipped
K03 = $500 + $30DV = +45 hp my 01 is at 214 hp
ko4 = $4-5000 = +75 hp my 01 would be at 244 hp
is 30 hp worth the extra $3500-4500?
or do I not know what I'm talking about?
Old Oct 2, 2006 | 04:47 PM
smokeU's Avatar
wait... 70whp? how many is that at the crank? and is the 45 from chip upgrade on k03 whp?
Old Oct 2, 2006 | 04:50 PM
DENIS415's Avatar
i think its around 75 at crank and its 40-50 with a KO3 setup,so im guessin if he had a KO4 it would be more then that....
Old Oct 2, 2006 | 04:56 PM
onepoint8tee's Avatar
A k04 setup is not $4-5k!!!
If you buy the parts seperate, unlike many k04 "kits", you shoulndt have to spend more than $2-3k for a full setup, including fpr, injectors, software, turbo, and exhaust.
You can get a k04 for $750 new, injectors maybe $300 (idk for sure), exhuast $200-$700 depending on whether its custom or not, fpr $50 max, software $600(?). Do the math. Even if you get a FMIC you should still be under or at about $3k if you are an informed buyer.
Old Oct 2, 2006 | 05:00 PM
Jeff's Avatar
Zombie Defense Force
true that. if you look around you can find killer deals. just dont be lazy. search the internet and it will save you lots of $$$
ORIGINAL: onepoint8tee
smokeU's Avatar
true. it doesnt add up. why is that kit so much?
Old Oct 2, 2006 | 05:01 PM
Jeff's Avatar
becuase people will pay for it becuase its simple and it requires little to no effort on the buyers part for finding parts
ORIGINAL: smokeU
