Pictures
50 and 20. Next i think ill get a miltek exhaust, then im not sure, ill go with a turbo upgrade, prolly either a ko4 or gt28r with all the other needed parts fmic, clutch, flywheel, dv, ect. Then wheels, tires, suspension and some exterior stuff (fk badgeless grill and some DIY stuff) Im open to comments i havent really desided yet.
Nice clean look. Recommend you get rid of the extra black plastic that will show below your license plate once you reinstall it. Just undo the bolts, pull off the plastic piece (it is attached with double face tape as well), and remove the excess with standard woodworking tools. I removed it with a few passes on my router table, and rounded the corners (although nobody will ever see them but me :-) ) - any wood saw, or a metal hacksaw will do though. It really showed on my silver car, and getting rid of it was the last thing the rear needed to look clean.
Some of the double face tape did not survive the process, but I didn't bother replacing it because it seems completely unnecessary.
You might want to consider a nice license plate frame as well, such as the brushed silver AudiSport available on AudiUSA.com (which surprisingly was cheaper at my local dealer than online).
