A-Pillar Gauges
Old Jan 1, 2007 | 04:48 PM
SouRce4's Avatar
Default A-Pillar Gauges
Looking to put 2 Gauges in the A-Pillar on my B5. I want to know besides Boost what is the 2nd most important gauge to put? Oil Pressure? Fuel Pressure? Air/Fuel Ratio? Or an Others?
Another question is is the 99.5 A4 similar to that of the 99-05 Jetta or 98-00 Passat?
Old Jan 1, 2007 | 05:04 PM
SMoLiK's Avatar
Default RE: A-Pillar Gauges
Boost, Oil Pressure, Exhaust Temp... The narrow band Air/Fuel ratio gauges are crap, fuel pressure really isnt needed unless your engine requires higher then stock fuel pressures, in which case just get a good high quality fuel pressure controller and a new fuel pump thenno worries there... Oil pressure is extremely important on a boosted car so I would say to go with that...
SMo'
Old Jan 1, 2007 | 05:05 PM
SouRce4's Avatar
Thanks alot sounds good.
Ill be placing my order shortly =]
ill post pics when its installed thanks again
Old Jan 1, 2007 | 05:07 PM
SouRce4's Avatar
Any ideas on the pod i need? Jetta or Passat?
Old Jan 1, 2007 | 05:22 PM
Jeff's Avatar
Zombie Defense Force
how about one of those huge tacks with the yellow shift light?/ jk about that one
ya boost and oil will be good. what about a wide band o2
Old Jan 1, 2007 | 05:30 PM
SMoLiK's Avatar
As Jeff said a wide band 02 would be areally goodidea, they are especially useful when you start tuning the air/fuel ratio (they are pretty much pointless until you start tuning the air/fuel)... Just dont waste your time/money on a narrow band 02 sensor...
SMo'
Old Jan 1, 2007 | 05:36 PM
Jeff's Avatar
see if you can a zeitronix wideband. i just got one for xmas and waiting for it to show up tomorrow. best a/f sensor on the market
Old Jan 1, 2007 | 05:38 PM
ou2mame's Avatar
Passats are pretty much based on a4's... I think jettas are more related to a3's since they use the same parts like brakes and stuff.
Old Jan 1, 2007 | 05:55 PM
Jeff's Avatar
they make them for a4's too
Old Jan 1, 2007 | 06:08 PM
AteUrV8's Avatar
EGT gauge.... exhaust gas temperature, very useful gauge.
