The plans to come.
Old Apr 4, 2006 | 10:58 PM
  #31
tip5's Avatar
Default RE: The plans to come.
Ill give you his number if you want to talk to him and get the details i bought the block and did the internal work myself with a coworker. The rest of build was done at a tuning shop and i never messed the 034.
  #32
TomRitt's Avatar
I think he's pulling your leg. If you've ever seen an aeb block, there is not enough cyl wall clearance to sleeve it unless you wanted to end up with a 1.6L or something
Old Apr 4, 2006 | 11:02 PM
  #33
tip5's Avatar
Thats what i thought but he showed me a stock aeb block compared to the one i bought it was a noticable difference it was sleeved, milled, dipped, and it was def a legit deal. So im not sure im getting my heads redone by him on this audi so ill get the info and post up.
Old Apr 4, 2006 | 11:14 PM
  #34
TomRitt's Avatar
yea def gimme his number I'd like to find out what advantage this has, because I know the oem german made blocks are good for over 1000hp
Old Apr 4, 2006 | 11:16 PM
  #35
tip5's Avatar
yeah im at work right now but i def will. He's doing my heads here in the next few months i get it done through him very cheap around 500-600$ range not to bad.
Old Apr 4, 2006 | 11:22 PM
  #36
TomRitt's Avatar
Also what boost level was that dyno at? u got any poics of the dyno sheet? Those are very impressive numbers for that that turbo
Old Apr 4, 2006 | 11:24 PM
  #37
tip5's Avatar
Nope it was dynoed and tuned and never touched as far as modding ever again it was over with thats how i do it. I dont have the numbers or sheets anymore i sold it with the car. With a full detailed list of all parts and everything that i had done to it and logged servicing. But a gt2 can flow over 600hp.
Old Apr 4, 2006 | 11:27 PM
  #38
tip5's Avatar
summer it hit 29psi with 660cc injectors and spiked at 33psi. Winter was alittle lower.
Old Apr 4, 2006 | 11:52 PM
  #39
TomRitt's Avatar
Ah i gotcha
ORIGINAL: tip5
Are we talking about the same turbo? the gt2 k24 can only flow about 300hp. It flows 600 on the porsche because they have 2 of em
Old Apr 4, 2006 | 11:53 PM
  #40
BadLuckAudi's Avatar
Lol Well two is better than one.....
ORIGINAL: TomRitt
Ah i gotcha
ORIGINAL: tip5
