Please help...erratic idle 2005.5 A4 B7
Old Aug 31, 2010 | 01:47 PM
RelentlessA4's Avatar
Default Please help...erratic idle 2005.5 A4 B7
I am having an idle issue with a 2005.5 A4 B7. I did some reading in the forum and decided to do the process of elimination by changing Air Filter and "cleaning" the Mass Air Flow Sensor.
The thing is what part of the sensor is needing cleaning? I took some pictures so you can see what I see, just show me where to clean.
Read to use Break Cleaner or Electric-Contact Cleaner but Avoid all electronics...
Please advise if you have any other information for the erratic idle...it only occurs when vehicle is warm and I am throwing codes....
P0507 Idle Air Control System/ Higher RPM than expected...
P0171 System Too Lean.....
Attached Thumbnails Please help...erratic idle 2005.5 A4 B7-imag0110.jpg   Please help...erratic idle 2005.5 A4 B7-imag0111.jpg   Please help...erratic idle 2005.5 A4 B7-imag0112.jpg
Old Nov 22, 2010 | 09:00 AM
jshutchins's Avatar
did you ever get this figured out? I am having the same issue. I am replacing the pcv valve and maf this week after checking all hoses for cracks/leaks.
Old Dec 20, 2010 | 04:16 PM
jshutchins's Avatar
Default update to erratic idle
I had a vac leak in my pcv valve, I throw the piece of junk away and did the bsh pcv fix. All gone, car idles perfect, no bounce, no hesitation. For fun i replaced the cam follower, and in the process broke my thrust sensor, which made my car not turn over, so I replaced it, cleared all codes, and have driven 1000 miles since with no codes and no issues. Love my car!
Old Sep 28, 2011 | 06:13 PM
The Problem was the PCV Valve....$80.00 from Audi. The car was getting a Lean Code and if I put the car in neutral it would idle surge up and down and then it would throw a code for High Idle.
Old Dec 16, 2011 | 11:46 AM
marcelogreat's Avatar
Unhappy PCV valve
Hey folks! I am having the same issue, engine rev up to 3000 rpm and at times goes down to 1000 or so but now mostly stays on 3000 . I was wondering where that valve is, I have 2005 a4 1.8 l turbo Thank you in advance!
gappel
Jan 1, 2018 02:41 PM
mattpan
B7 Models
Nov 10, 2010 02:10 PM
rmarney
Feb 18, 2008 06:42 PM
pmarley
Sep 2, 2005 09:24 PM
grahm
Apr 27, 2005 11:18 AM
