PLEASE HELP NOW!!! BRAKE PROBLEM (solved, PICS)
Old Nov 17, 2007 | 02:52 PM
RaFa's Avatar
Default PLEASE HELP NOW!!! BRAKE PROBLEM (solved, PICS)
99Audi A4 1.8T FWD....
Imchanging the rear brake pads and rotors....the rear i took the caliper and already compressed the piston, i tookout the other part that holds the caliper on the rotors, from what i rear the rotors should just come out! Is there a screw holding the rear rotors? i cant takethem out.
Please help!!!
Old Nov 17, 2007 | 03:14 PM
RaFa's Avatar
Default RE: PLEASE HELP NOW!!! BRAKE PROBLEM
come on people, no body? i did a search! i have a diy open! but it says after the rotor should just come off!!! and it doesnt!!!!!!1 please help!
Old Nov 17, 2007 | 04:21 PM
auditech79's Avatar
What problem are you having, that you can't break the rotor loose or that you can't swing it out of the caliper bracket?
Old Nov 17, 2007 | 04:23 PM
FASTER's Avatar
Tech Slut
little bit of penetrant and light tapping with a rubber mallet should do the trick. if you dont have a rubber mallet soften the blows with a piece of wood.
Old Nov 17, 2007 | 04:28 PM
oettinger1919's Avatar
SoCal Crew Member
ya i had the same problem its just corrosion build up that locks it on...
Old Nov 17, 2007 | 05:21 PM
onepoint8tee's Avatar
As long as the caliper is out of the way it should come off. Just beat the **** out of it with something being careful not to **** up the hub. You knowyou will need new rear wheel bearings right?For FWD, they are pressed into the rear rotors, not thehub. Also remember to remove the ABS ring that is pressed into the old rotor to put in the new.
I used a giant socket bit (cant remember what size) and a hammer to press in the new bearing racesinto the rotors btw.
Old Nov 17, 2007 | 10:52 PM
RaFa's Avatar
Default RE: PLEASE HELP NOW!!! BRAKE PROBLEM (SOLVED)
ORIGINAL: onepoint8tee
Yea after a while i figured it out, the only thing it was left it was taking the wheel bearing, which didnt say on the diy, i took the old stuff and put on the new rotor, everything looks good. didnt have time to finish everything cuz it got dark so theres one wheel left and i should finish tmw. otherwise everything looks good =) I'll post pics later tmw.
Old Nov 17, 2007 | 10:58 PM
You reused the old bearings? [&:] How did you get the old races out?
Old Nov 17, 2007 | 11:03 PM
RaFa's Avatar
Ididnt bang the rotors to come out, there was a lil cap that covered the middle of the rotors you have to take it out,thenItook out the lil pin, the screw and the bearings came out, the only thing i had to bang it out of the old rotors is the rings that the bearing sit on (one in the front and one in the back) then i took everything out, put on the new rotors with some new grease, put everything back together, and there you go..looked like new.
Old Nov 17, 2007 | 11:09 PM
Look in your old rotors. There is a ring (the race) pressed into the inside of them that the bearings roll against. The bearings will fail within a few miles if you dont have a race in there. The bearings will just flop around. Maybe Im not understanding you. How can you bang the races/rings out without killing them to reuse?
