Please help with wheels
Old Apr 13, 2005 | 03:45 PM
cdretc's Avatar
Default Please help with wheels
Hi Audi Fans,
I have a problem with my wheel fitting for my Passat. I need some help.
I also have a thread at the VW forum. Here is the link:
http://www.vwforum.com/viewtopic.php?p=152892#152892
In short: I wanted to put on the widest possible tires on my ride without any mods/rubbing. Most people agreed that 225 would do fine, whereas with 235 I can run into some problem. Now, I managed to pick out a set of wheels, but I'm worried that they won't fit.
Here is what I mean: I just found out today that stock VW wheels have 37 mm (on 17x7") and 45 mm (on 17x7.5") offsets. The OZ Superleggeras are 17x8" with offset of 35 (p/n SL780M35L-RS). These are the only ones that come with 5x112 bolt pattern. That makes it deviate almost 1" from stock. Am I in trouble?
Thanks for the help and input.
Old Apr 13, 2005 | 03:47 PM
brrman's Avatar
Default RE: Please help with wheels
you are fine unless your car is slammed.
Old Apr 13, 2005 | 03:51 PM
Aliel's Avatar
I have an Audi A4 1.8T Quattro and I have 18x8 OZ Superleggeras with 225/40ZR18 Toyos. I don't know about 235s though.
Old Apr 13, 2005 | 03:53 PM
cdretc's Avatar
Sorry, what do you mean by slammed?
What wheels/tires do you run? They look awesome...
Old Apr 13, 2005 | 03:54 PM
Jestnomen's Avatar
6th Gear
slammed = lowered suspension
Old Apr 13, 2005 | 03:57 PM
cdretc's Avatar
Thanks Aliel. That's very reassuring. I see that the 18" ones also have 35 mm offset. So you have no rubbing at all, right? Not even when the wheels are fully turned? I have to turn my wheels out all the way several times, for the stupid parking at work...
I am thinking of putting 225/45/17 Michelin Pilot Sport PS2's on.
Old Apr 13, 2005 | 03:58 PM
brrman's Avatar
I run 235's on 18x8.5 (et35) wheels. Lowered suspension (sport). I have no rubbing issues. On my sedan I had the same setup but with race suspension and I rubbed.
cdretc's Avatar
Thanks Jestnomen. I guess there is a good reason why it says "Newbie" under name login name
Old Apr 13, 2005 | 04:01 PM
TomRitt's Avatar
i run 235's and a very lowered suspension and 9" wide wheels, i sed to rub nut after cutting out my fender liner and rolling my fenders no problems
Old Apr 13, 2005 | 11:26 PM
chriscollins's Avatar
can someone please define 'rolling your fenders' for me? i hear that term but not sure how/what it does to allow for lowered suspension/tire situation. thanks for the vocab lesson in advance.
chris
