PO102
well i just got it chipped with GIAC. Before that i Had a problem with boost and it threw out a code, so i cleaned the maf sensor( can't remember the code # think it was po171), after I cleaned this out my boost was back to normal(10psi), now that I have gotten it chipped sometimes it goes to 18psi, but mainly it stays right around 12-14psi. I don't think this is normal most people that I have read with GIAC chip are around 17-19psi.
I don't know what to do.
Sounds like a bad connection to the maf, check the wiring harness, maybe clean it, or possibly a bad MAF.
search box at bottom, put in P0102 get about 100 threads with same problem.
Check the connection first, thats the easiest thing to do.
I had that code 2 years ago. I had the MAF replaced with a remanufactured one from;
www.ecstuning.com
The code has not returned.
www.ecstuning.com
ORIGINAL: mikejda
[:@] My car is now throwing this code at me.
PO102 MAF or VAF A circuit Low input
Please help thanks
Please help thanks
swap the maf and you should be good to go (after clearing the codes ofcourse)
Peace
ORIGINAL: whitejeepXJ
I had this happen and I had the wiring traced all the way to underneath the dash... took HOURS.. turned out to be a bad maf... when the maf reads 0 it gives out this code.. when it reads bad numbers.. either too high or too low.. its another code...
Peace
ORIGINAL: mikejda
Please help thanks
Please help thanks
Peace
