Poor Gas Milage
Old Mar 8, 2005 | 06:15 PM
nolander's Avatar
Default Poor Gas Milage
I have an A4 2.8 liter V6 and have been getting about 17mpg according to the trip computer. Should'nt I be getting better mpg?
Old Mar 8, 2005 | 07:13 PM
Jestnomen's Avatar
6th Gear
Default RE: Poor Gas Milage
how many miles?
Old Mar 8, 2005 | 07:18 PM
nolander's Avatar
I have about 51,000 miles on the car. I generally get about 260+ miles per tank of gas. The manual says that the car has a 16 gallon tank, but it seems to only take about 14 gallons when the car says it's on empty with 5 miles left. The manual mentions a 2 gallon reserve. Does this kick in when I use the 14 gallons?
Old Mar 8, 2005 | 07:22 PM
Jestnomen's Avatar
6th Gear
It should show empty and then you will still have 2 gallons left. 260 per tank is better than I've ever been able to get! You may want to replace your O2 sensors, as they can cause bad gas mileage.
Old Mar 8, 2005 | 07:33 PM
mainer's Avatar
are you serious? you both have v6's?
i guess i'm glad i didnt get a v6.... i get 200 on a half tank driving around town...with my 97 1.8t q manual with 192,000 miles
Old Mar 8, 2005 | 07:41 PM
nolander's Avatar
Thanks Jestnomen! I guess that's the price you have to pay for the V6! I've searched on "gas mileage" and there were suggestions to replace plugs as well. Would you recommend that as well? What about fuel intake cleaners? It seems that is also recommended.
I appreciate all the help!
Old Mar 8, 2005 | 11:56 PM
david9999's Avatar
Try some fuel injector cleaner (Techron or Redline brand).
Plugs if you haven't changed them recently (like 30K miles).
When is the last time you did basic things like air filter. Are your tires under-inflated?
Could be failing o2 sensors. They fail slowly and may not throw a CEL yet.
Has there been a loss of power? Find someone with a VAG.
Am I glad I didn't get a v6. Last tank I registered 30.5 mpg (Chipped, all highway)
Old Mar 9, 2005 | 01:49 AM
apg96's Avatar
i have a v6 and get 16 all city driving and i am going to use some injector cleaner on the next tank. I will post some results. I think i will get the plugs checked and the o2 sensors. i have 78,000mi should i need this?
Old Mar 9, 2005 | 02:04 AM
PandaXpress's Avatar
damn i get like 17 and i have thje 1.8t
Old Mar 9, 2005 | 02:21 AM
BFlan's Avatar
jest, i tried to find the gumout regain stuff you recommended, but i only found gumout fuel injector cleaner. i figured that was it, but is there some other product called regain that i didn't see?
