Power Sunroof = Keyless Entry??
Old Apr 15, 2006 | 11:33 PM
landsknechte's Avatar
Default Power Sunroof = Keyless Entry??
Is a 1997 A4 with the power sunroof supposed to have keyless remote entry? If so, how would one go about getting a remote that works, if the car doesn't already have one?
Thanks,
--Chris
Old Apr 16, 2006 | 02:35 AM
Jestnomen's Avatar
6th Gear
Default RE: Power Sunroof = Keyless Entry??
All 97s had keyless entry. You can go on ebay and find a three button (lock, unlock, panic) switchblade with a blank key if you want. The two I bought off of ebay came with programming procedures too.
Old Apr 16, 2006 | 03:09 AM
Cool... Thanks for the info!
Old Apr 16, 2006 | 07:34 AM
This type?
...also, is there anything more to getting a second key (not fob) cut than literally having it cut? In other words, are they transponder keys?
Old Apr 16, 2006 | 11:56 AM
hb972.8q's Avatar
yep. to get the key cut you have to bring it to a dealer. it cost me $45 if you want they can also program it to. or you can find the instructions on line here or on aw it is realy simple
Old Apr 16, 2006 | 12:00 PM
hb972.8q's Avatar
oh i forgot i belive you have to reprogram you ecu to get the windows and sunroof to open/close with the remote. just fing some one with a vag it should only take 2 min to do
Old Apr 16, 2006 | 06:37 PM
I may not have a choice but to go back to a dealer for programming, as I only have one key for it. (...and if I'm not mistaken, you need two keys to program a fob, right?)
Thanks,
--Chris
Old Apr 16, 2006 | 07:18 PM
StevenTownsend's Avatar
and if you put the key in the keyhole and hold it to the left, all the windows roll down. ;] and if you hold it to the right, they will all roll up. including the sunroof if it's open or cracked ;]
Old Apr 16, 2006 | 09:08 PM
Just discovered how to control the windows via the key this afternoon, quite by accident. Startled me a bit, as I wasn't expecting parts of the car to move independently. [sm=insomnia.gif]
Old Apr 16, 2006 | 09:46 PM
haha yep. the greatest part is when you turn it to the right and the sunroof closes. it's a nifty little feature. unfortunately it doesnt' work keylessly hha
