problem with chip
Old Dec 25, 2006 | 03:48 PM
Lipscomb29's Avatar
Default problem with chip
i got an APR chip and when im driving it will shut off beacuse it thinks its over boosting or something. is this a normal problem... does it have to do with my car or the chip? help please!!
Old Dec 26, 2006 | 01:32 AM
Lazer Viking's Avatar
Default RE: problem with chip
do you have a boost controller ?
throwing any codes ?
Old Dec 26, 2006 | 03:59 AM
NuYorka103185's Avatar
Mine does it all the time. If I hold full throttle for longer then 4 or 5 seconds it kicks me down to stock. Really sucks. Are you hearing a loud air sound when you floor it, like air rushing through a pipe??
Old Dec 26, 2006 | 05:50 AM
brrman's Avatar
If you checked your codes you will likely see a "17964 charge pressure control: negative deviation" code.
Often points to a boost leak.
If you have changed your N75 valve you might want to look into a different model.
Old Dec 31, 2006 | 09:10 PM
Lipscomb29's Avatar
ya i have a vag system now, and thats it.
its just annoyin to fix it all the time.
i dunno if i hear anything. i can feel it when i hit the gas u just feel it drop in the pedal
Old Jan 2, 2007 | 10:08 PM
Lipscomb29's Avatar
u think its a leak somewhere? i had the guy that installed it change the d.v. and it still would turn off the chip.
Old Jan 2, 2007 | 10:29 PM
onepoint8tee's Avatar
Used to happen to me all the time just as described and after i put my exhaust on it doesnt happen anymore.
Old Jan 3, 2007 | 09:50 PM
Lipscomb29's Avatar
what kind of exhaust did u get? im thinkin about gettin milltek because i have a fwd and borla doesnt make one for me
Old Jan 3, 2007 | 10:11 PM
ORIGINAL: Lipscomb29
I have milltek, as stated in my sig!
Old Jan 3, 2007 | 11:27 PM
BadLuckAudi's Avatar
yes there is a borla kit for you man check out techtonicstuning they sell one that fits just call and talk to them
