problems with the chip
Old Sep 5, 2006 | 02:10 AM
Lipscomb29's Avatar
Default problems with the chip
i got my car chipped a week ago and i was driving down the road yesterday
at the speed limit and then all of a sudden the chip shuts off, and i have no boost.
any advice would be great, thanks
Old Sep 5, 2006 | 02:13 AM
Jeff's Avatar
Zombie Defense Force
Default RE: problems with the chip
chips dont shut off something else happend. did you check all vac lines? did you go into limp mode? do you have a boost gauge? if so what are you reading
Old Sep 5, 2006 | 02:25 AM
Jovian's Avatar
When you ment shut off did it feel like there was no turbo at all (limp mode) or that it went back to stock settings (still turbo but only about 7 or so PSI boost)?
Old Sep 5, 2006 | 02:28 AM
onepoint8tee's Avatar
Its probably still adapting. Give it some time, like 3 weeks before you get freaked out by inconsistant performance.
Old Sep 14, 2006 | 09:36 PM
Lipscomb29's Avatar
it went into limp mode. i went to get it fixed 2 times already and it still goes into limp mode.
im not even pushin the car hard at all.
Old Sep 14, 2006 | 11:13 PM
simon17's Avatar
is it boosting then going into limp mode?
I had a problem where my car was overboosting and going into limp mode. have you got them to check your diverter valve? it may be stuck open
Old Sep 15, 2006 | 02:20 AM
audiguy00's Avatar
i am experiencing the same thing with mine! i have had it chipped for about 10 months now... and it does it atleast once a week. and it will only do it at part throttle. if i'm in it full bore it will be fine. or keeping it in vaccum. but if i try to just drive at part throttle and put a load on it... then it slips into limp mode. i only spike like 9lbs and it will only hold 3-6. pisses me off but no one knows whats going on... checked everything.... i have an apr chip what chip do you want. and has anyone else had this happen to them. i have to drive it either a real light touch on the throttle or just smash it.
let me know please
thanks
bobby
Old Sep 15, 2006 | 02:24 AM
18T's Avatar
18T
B5 = GIAC
Old Sep 15, 2006 | 02:25 AM
simon17's Avatar
just smash it mate!! too easy!!
Check that your diverter valve is not sticking!!
Old Sep 15, 2006 | 02:26 AM
audiguy00's Avatar
nope not sticking.... brand new
also the car loves to shoot 20ft flames out the exhaust.
