PROBLEMS PROBLEMS!
Old Dec 5, 2004 | 05:51 PM
99AudiA4q's Avatar
Default PROBLEMS PROBLEMS!
Alright so i went to a local performance shop and i bought from them a performance intake.. You know, gotta have some sound till i get my PES in.hehe... 2 days later my check engine light came on... When they did my intake they had told me i needed to buy a breather and put it in the vac line so i did (after my check engine light came on) I went o auto zone and their tester wasnt linking at all. Wat could the problem be? The car is still running the same i feel no difference.
99AudiA4q's Avatar
Default RE: PROBLEMS PROBLEMS!
Be adviced the intake was custom made!!!!!
Old Dec 5, 2004 | 06:13 PM
04a4's Avatar
Have you run a VAG-COM diag. yet? If you don't already have one, i would highly recomend getting that program and cable to hook up to your ECU... It is a life saver and saves you from a bunch of headaches...
Old Dec 5, 2004 | 11:53 PM
99AudiA4q's Avatar
where could i get that problem? I really need help in this. Hey the check engine light came off today after i left my job, kinda weird figured the problem solved itself
Old Dec 6, 2004 | 02:36 AM
Jestnomen's Avatar
6th Gear
The CEL will extinguish after X amount of miles if it was a one time deal. Intake conditions, which usually relate to lean/rich conditions normally aren't an ongoing condition. They happen sporatically. The fault code(s) are still there though. Without Vagging the car there's no way to tell what the problem. You don't even know if it is related to the intake. I mean you may have not tightened the gas tank!
Old Dec 6, 2004 | 02:06 PM
99a4audi's Avatar
my friend put an intake on his car and the check engine light came on. make sure its tightly on, his intake was a little loose
Old Dec 6, 2004 | 05:09 PM
99AudiA4q's Avatar
yea now that i think of it, i was a little stupid one day at night and i spilled gas by my gas tank LOL i wasnt paying attention i was pissed cause the pump didnt wanna keep pumping even tho it was on empty. hey 99a4audi wat part of mass do u live in? im in somerville
Old Dec 6, 2004 | 10:11 PM
David_K's Avatar
What does this have to do with anything?
Old Dec 6, 2004 | 10:52 PM
99AudiA4q's Avatar
supposedly the check engine light goes off when the gas cap isnt tight! or so i heard from auto zone
Old Dec 6, 2004 | 10:55 PM
Jestnomen's Avatar
6th Gear
Yes that is true, the gas system is pressurized for environmental reasons. But I said it jokingly in that there is no way to tell what the CEL means.
