pulling the radiator support forward - SNUB
Old Nov 7, 2006 | 07:21 PM
wood_e's Avatar
Default pulling the radiator support forward - SNUB
So I followed apr's directions and removed the side screws below the turn signals (step 13) and I can't seem to move the support forward. Anyone have any tips?
Old Nov 7, 2006 | 07:33 PM
techbod's Avatar
Default RE: pulling the radiator support forward - SNUB
#1/2 don't know if this will help
[IMG]local://upfiles/12092/B481DC46AC744E24B781D5EBCACCFEF8.jpg[/IMG]
[IMG]local://upfiles/12092/93FE8F61381C4FB4A98FF5B7A98E7501.jpg[/IMG]
Old Nov 7, 2006 | 07:38 PM
techbod's Avatar
#3 sorry for the delay hacker problem
[IMG]local://upfiles/12092/3D1D4B11C51E4B71BEAC604A2FD69554.jpg[/IMG]
Old Nov 7, 2006 | 07:46 PM
onepoint8tee's Avatar
All you should have to do is remove the bumper, unbolt the ac condensor and slide out of the way and then remove the bumper support shocks.. And also the tabs on top of the radiator. Then it should be able to slide forward enough to squeeze the snub on.
Ive done it twice this way before... and a crow bar helps a lot when trying to get the snub onto the spindle if there is still limited room to work with..
Old Nov 7, 2006 | 10:06 PM
wood_e's Avatar
Well I got it on by removing the spindle and pressed the new snub on.
Old Nov 7, 2006 | 10:34 PM
luvin_the_rings's Avatar
i had to use a clamp to press the new snub on, i busted a piece of thick steel inbetween the radiator and the other side of the clamp.
Old Nov 7, 2006 | 10:44 PM
wood_e's Avatar
I put my snub in the micro for a minute, and it was REALLY hot, but I just put it on the spindle and put my weight on it and it fit.
Old Nov 7, 2006 | 11:07 PM
i put my snub in the micro for 30 sec's and it fked it up, straight melted it, i had to get a new one...
lespaul2510
Feb 4, 2014 05:14 PM
3.0audi
Dec 17, 2010 03:56 AM
zensane
Dec 13, 2010 08:04 PM
neomaxddr
Mar 28, 2009 07:16 PM
cvacc411
Jan 29, 2009 04:58 PM
