Pulsing speedo and no tach !! Please help !!
Old Mar 1, 2007 | 02:48 AM
josephap8764's Avatar
Default Pulsing speedo and no tach !! Please help !!
I just had to jump-start my car because I switched the lights on and left them for about an hour ....only had about 8 volts ...not enough to crank .
So I jumped it and after I did .....the speedometer pulses between like 0 and 4 mph ..no matter how fast I am going and the tachometer just sits there like it's dead ....I've tested all the fuses and they are all good . All lights and other guages work but not the speedo and tach .
I am really in a fix here cause i have to drive this car and i won't know how fast I am going !
Old Mar 1, 2007 | 03:10 AM
Default RE: Pulsing speedo and no tach !! Please help !!
Also there is a clicking noise every time the speedometer twitches ...which is about 3 times per second ! I can't find anybody else who has had this problem . I've been looking on the forums for the last 30 minutes !
Old Mar 1, 2007 | 05:00 AM
Audi_Skydiver's Avatar
Try disconnecting the battery for a few min. then re connecting it. I am pretty sure this will re-set your ECU and hopefully will fix it!
Josh
Old Mar 3, 2007 | 03:09 AM
tractioncontrol's Avatar
Replace the battery.
Old Mar 12, 2007 | 01:18 AM
Don't know how it happened but ended up being the instrument cluster ..I am guessing a voltage spike took it out or something . I got a used one off eBay for $100 to use temporarily and I am sending my broken one to www.bba-reman.com . They will repair it and give me a 2 year warranty . Anybody ever dealt with them ?
02AudiA43.0
Apr 6, 2014 03:45 PM
garruk
Oct 14, 2010 12:57 PM
99A6Quattro
Feb 2, 2009 07:26 PM
velvethands
May 10, 2008 02:03 AM
slocumnb
Mar 14, 2006 12:59 PM
