Purchased Forge Splitter - Good Choice?
Old Dec 11, 2007 | 06:39 PM
Jeff's Avatar
Zombie Defense Force
Default RE: Purchased Forge Splitter - Good Choice?
i just went in there with a chainsaw.
Old Dec 11, 2007 | 06:54 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: auditech79
ORIGINAL: cincyTT
that or a tiny eyeglass screw driver works great
I don't know where you get these kinds of ideas, but that would work great.
I have logic on my side. You just use the tiny flathead and pry up the end and then either needle noises or a normal flatheadto pop it the rest of the way off. Takes no time at all. Only problem is if the end isnt easy to get to, it takes a little bit more time sice you have to work in the middle
Old Dec 12, 2007 | 10:21 AM
drs305's Avatar
Member
How many clicks to tighten the valve? On previous posts everyone seems to be doing about ten. Is this a good amount with a chipped 1.8t.
Old Dec 12, 2007 | 11:04 AM
veloracer's Avatar
ORIGINAL: cincyTT
That's how I got them off. Probably the best way to do it.
Old Dec 12, 2007 | 02:02 PM
chaos92287's Avatar
i have this tool from Crescent called a precision driver. its basically a screwdriver with an extendable spring neck to allow you to get to places a normal screwdriver cant and a selection of 30 small screwdriver and torx bit. i used it to swap a friend of mine's DV and it was cake to get those clamps off
Old Dec 12, 2007 | 02:04 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: drs305
you should be somewhere in the teens.
Old Dec 12, 2007 | 04:57 PM
operator's Avatar
Ive got an APR stage 1 flash and it took me close to 20 clicks. Been using the splitter for 2 months now and no problems at all. Dont think you'll hear a woosh like a BOV though, cause its only noticable when I go from full throttle with the stero off.
SunnyShaida
Dec 5, 2008 05:35 PM
APRaudiA4
Apr 30, 2008 06:41 PM
dqx2001
Jan 9, 2008 06:25 PM
vegastt
Sep 4, 2007 12:18 AM
DiscoStu9
Aug 13, 2007 04:39 PM
