Quattro Mechanics..??
Old Dec 28, 2007 | 08:24 AM
SLVR99A4's Avatar
Default Quattro Mechanics..??
Could someone briefly explain the mechanics of our Quattro AWD system. I currently drive a 99 A4 1.8TQ Tip and had some trouble in the snow. Last year this thing was a tank in the snow and this year I already got stuck twice in the first two snow falls of the year, believe me I do own an AWD Audi. In the first instance I was pulling out of my parking spot (minimal incline) in about 4 inches of pretty dense icey snow and got hung up, wouldn't budge. Now the car was not parked perfectly flat as the car was pitched a little uneven due to the swale at the side of the road (passenger side of car was a little lower than driver side). As I was rocking the car between Drive and Reverse only two of my tires were spinning, both front and rear driver side wheels, the outers had no power. I understand it operates as an open differential (front and rear), transferring power to the wheel that needs it, in this case I needed power to my outers.Ashamed, I had to get out and dig myself out eventually breaking free.The second instance I drove into the some deeper, hard icey snow and got the bottom end hung up again getting stuck. Although I was in fault, again only two wheels were spinning not all four..?? Why is this? I thought at low speeds especially in first at take-off the quattro system should operate like positraction and then back off power-transfer at higher speeds...?? What do you guys recommend doing when caught up like this?? Any advice or information would be greatly appreciated, thanks.
Old Dec 28, 2007 | 10:02 AM
Redrum1's Avatar
Default RE: Quattro Mechanics..??
Maybe you can gain the knowlege your seeking by reading about the Torsen Differential here:
http://www.autozine.org/technical_sc...tion_4wd_2.htm
Good Luck...
Old Dec 28, 2007 | 10:15 AM
Lazer Viking's Avatar
Old Dec 28, 2007 | 10:41 AM
SLVR99A4's Avatar
ORIGINAL: Redrum1
Good Luck...
Great reference, great knowledge, thanks.
RedTTQ
Jan 3, 2008 04:22 AM
A6 Quattro V6 30V
Dec 9, 2006 05:30 AM
vigorcomp
May 17, 2006 01:32 PM
lilbrownindian
Oct 7, 2005 02:10 PM
VolcanicBlackA4
Jul 18, 2005 12:34 PM
