Question about b5 A4 audio system...
Pulled my door panel off today because I had a blown speaker. Came to discover that my car uses 4 1/2 inch speakers, and they have a triangle bolt pattern instead of a square pattern.
Is there anywhere in the US where I can buy an adapter for these speakers? Also, I went to buy a new set of 5 1/4 inch speakers to retrofit myself, but I was told that I could not replace the speakers without replacing the entire stereo. (I did explain to him that I did not have the bose system) Is there any truth to this? How hard would it be to re-wire everything myself? Thanks alot for any help!!! |
RE: Question about b5 A4 audio system...
use the fxcking search function
ORIGINAL: Lazer Viking use the fxcking search function |
the doors do have 5 1/4" speakers. maybe someone changed them out before and put 4 1/2 cuz they couldn't find a way to put 5 1/4's in the door. its a little tricky but can be done
o i jus noticed you didnt have bose so maybe urs aren't 5 1/4". you should be able to find an adapter for it pretty easy tho. try sounddomain or maybe egay |
