Question About Diverter, I called APR
Old Dec 13, 2006 | 06:34 PM
edkwok's Avatar
Default Question About Diverter, I called APR
I talked to Ecodetuning www.ecodetuning.com, and ask which diverter valve is good for B7 2.OT,
they told me this one, click me
I did search on this forum, and Audi use Diverter valve, not Blow Off Valve,
but Ecodeturning said 2.OT originally used DV, but BOV is a better fit for it.
What do you guys think?
Will that product work in that link for my B7 2.OT?
Old Dec 13, 2006 | 06:58 PM
turbo kraut's Avatar
Tech Guru
Default RE: Question About Diverter, I called APR
i called ecode and they told me the same thing, i called apr and he told me to go with the stock one
so my recomendation is go with your stock one, the main reason he said this is that the stock has a rubber gasket that moves aftermarket has a metal one that moves, he said wait till your stock craps out then think about getting another stock one unless you are running upwards of 500hp
Old Dec 13, 2006 | 07:17 PM
swift_A4's Avatar
upwards of 500hp, rofl, @ that amount of power i would assume you would (maybe?) be running standalone w/ bov
Old Dec 13, 2006 | 07:46 PM
GTOrleans's Avatar
just upgrade to the Audi TT's diverter, they are meant for more hp, theyll stand up to bigger power, definetely not 500 hp though.
Old Dec 13, 2006 | 07:49 PM
LabattZ's Avatar
w/o opening up a can o' worms ...
that DV vents atmospherically. you don't want to do that. Stay w/ a recirculating DV.
Old Dec 13, 2006 | 08:19 PM
edkwok's Avatar
So, I should get the Audi TT DV?
Old Dec 13, 2006 | 08:34 PM
Lazer Viking's Avatar
or you could search, because this has been covered a few million times,
either 710n, forge 007
you should be fine with a 710 i dont forsee major tuning comming from you
Old Dec 13, 2006 | 08:39 PM
swift_A4's Avatar
the new 2.0T motor is completely different in the aspects of a DV than the 1.8t motor from the b5 and b6. i think this has been covered before but you cannot just replace the dv, i think there are aftermarket add-ons/ a peice you can replace when you get the car chipped.
Old Dec 13, 2006 | 09:30 PM
socaljoe's Avatar
SoCal Crew Member
So far, the only option for the B7 is the DVSFit and the C version
Old Dec 13, 2006 | 10:38 PM
swift_A4's Avatar
the c-version, that is what i was trying to remember
