Question after changing MAF
Old Aug 1, 2005 | 04:47 AM
18T's Avatar
18T
Default Question after changing MAF
After having a boost leak and changing the MAF the other day i have realized something isnt right with my car. It burns way too much gas than before.
My car seems like it has way more boost now than it did before the MAF failed. It pulls like crazy.
Could they have done something at the dealer when they changed the MAF??
im not complaining about the boost, but the fuel economy is worse than my mom's navi.
thanks
Stef
edit: Oh one more thing.. wahts the largest size tire that can fit on a 17x7/7.5. im thinking of getting 225/40/ dont know if it will fit though
Old Aug 1, 2005 | 01:06 PM
18T's Avatar
18T
Default RE: Question after changing MAF
any ideas?
Old Aug 1, 2005 | 08:44 PM
david9999's Avatar
What year and mileage? Could your MAF been causing you to run lean, and a bad oxygen sensor causing you to run rich have been balancing each other?
Old Aug 1, 2005 | 09:31 PM
CRAZYHAWK's Avatar
Wouldn't each of these generate CELs?
Old Aug 1, 2005 | 11:35 PM
black b5's Avatar
18T check your fuel economy the manual way, not by the trip computer
gallons after fillup divide by miles driven. i know it sounds simple but my trip computer has been off a few times
maybe you have just been heavy on the foot feed since its running right[sm=gears.gif]
225/40/17............ what is your stock size? that just doesnt sound like the same overall diameter
Old Aug 2, 2005 | 01:35 AM
18T's Avatar
18T
Im getting Dan's wheels. they are 17's. not sure if they are x7 or 7.5
so i dont know how wide a tire to put on there. i want to go with the max width
Old Aug 2, 2005 | 01:44 AM
lidonnit's Avatar
ORIGINAL: black b5
How do you work that out? Your Trip meter & ODO run from the same thing? .... Don't they. Mine are always spot on.
Old Aug 2, 2005 | 04:46 AM
18T's Avatar
18T
Eh?
Old Aug 2, 2005 | 04:56 AM
black b5's Avatar
ORIGINAL: 18T
my sport came with 205/55/16 which has a overall diameter of 24.87 in.//// yours should be the same
the 225/40/17 tire you want to put on has a overall diameter of 24.08 in.
you speedometer would be off by 1.9 mph @ 60 mph and in the long run put more miles on the odometer than you really have
still with me??
i would recommend a 225/45/17 which is still off by .3 mph @ 60mph but it it closer.
dont go any wider than 225 section width on a 7.5 in wide wheel
Old Aug 2, 2005 | 04:59 AM
18T's Avatar
18T
thank you very much! i will go with 215's i think. i really like the 225 width.. but goddamn.. i forgot what i was gona say...[sm=WTFsgign.gif]..
