Questions before i put in my HFC and Borla
Old Jul 14, 2007 | 01:06 PM
pv1127's Avatar
Default Questions before i put in my HFC and Borla
Hi guy's. well i just ordered my High Flow Cat and my borla cat-back kit and this is going to be my first full exhaust job. Is there a special tool i will need to get my O2 sensor's out? or can i just use a Regular open end wrench? and r they sensitive, easy to break or anything like that. Thanks.
Old Jul 14, 2007 | 01:15 PM
onepoint8tee's Avatar
Default RE: Questions before i put in my HFC and Borla
With the airbox out, you can easily use an open ended wrench to get at the primary 02 sensor. Before that though, make sure you disconnect the wiring harness's from the 02 sensors by the coolant resevoir. Take the primary 02 sensor out and leave the rear one in (it can come out when the cat comes out). The bolts that attatch the cat/hfc to the down pipe is a major PITA, but doable. Just use a lot of PB blaster. You cannot remove the whole exhaust with the cat still attached to it. It will make it easier to get the cat out if you take the exhaust off first (down pipe back). That will aloow the cat/dp to flex more so you can get at the cat/dp bolts more easily.
Old Jul 14, 2007 | 01:26 PM
pv1127's Avatar
Thanks onepoint8tee i have access to a lift so im sure that is going to help me out a lot
Old Jul 14, 2007 | 01:32 PM
Which means you have access to air tools- Even better!
Old Jul 14, 2007 | 01:45 PM
pv1127's Avatar
Yup im in the military so we have a place called the "hobby shop" on base that has almost every tool you would ever need. Thanks Uncle sam!!!
meezy33
Jun 4, 2008 11:12 AM
candycane84
Jan 11, 2008 01:13 PM
18T
Jul 18, 2007 07:27 AM
careycj0219
May 2, 2007 01:44 PM
OH 44
Jan 13, 2005 10:48 PM
