Quick! Debadging help!
Old Feb 7, 2006 | 08:11 PM
StevenTownsend's Avatar
Default Quick! Debadging help!
okay, i just took the first symbol off. used a goo gone type thing to try to get all the adhesive off.. everything is off but i can see a faint outline of the A.. what can i do?! is there any hope to get that off or should i look into purchasing a new a or some new sticky tape to put it back on? i've heated the outline and tried an adhesive remover for a long time now.. also tried a scratch remover.. and bug and tar remover. none worked.. it's raised a bit. someone help please.
Old Feb 7, 2006 | 08:13 PM
BadLuckAudi's Avatar
Default RE: Quick! Debadging help!
You can try and use a buffing or polishing compound but be careful you can burn the paint if your too agressive with it, just take it easy and then re-wax after that and it should be good
Old Feb 7, 2006 | 08:18 PM
hmm i have the compound, should i just put it onto a shirt and rub it onto the area really lighty? and that should take it off?
Old Feb 7, 2006 | 08:21 PM
Peteman187's Avatar
First of all take off all the badges or else ur creating more work for yourself. Once you have goo goned and scraped till you can't anymore compound. I used a buffer and it really helped. There is gonna be a faint outline for about 2-3 weeks but it will completely dissapear
Old Feb 7, 2006 | 08:22 PM
just tried, didn't work. i think it's imprinted into the paint.. what should i do?
Old Feb 7, 2006 | 08:23 PM
there will be an outline for a while?
Old Feb 7, 2006 | 08:24 PM
Peteman187's Avatar
On mine there was. I also have pearl white (a tricolor) and a 97, so thats probably why. I promise though you will be able to get it all off. Some people said claybar too
Old Feb 7, 2006 | 08:28 PM
so i should keep going right?
Old Feb 7, 2006 | 09:14 PM
Peteman187's Avatar
O yes
Old Feb 7, 2006 | 10:15 PM
haha done. got as much off as possible. you can barely see it.. only ifyou look at 13°W into the sun squinting with one eye open.. it should go away with a few washes and waxes. and viola, here she is.
[IMG]local://upfiles/12576/AFA53FE6B97845BDA1685C719717B5E4.jpg[/IMG]
